08-02-2004, 07:55 AM | #26 |
Ogier,
I wasn't trying to be a smart azz....I know all of the CFM formulas too. I always fall back on what GM did, and ofcourse personal experience. For a daily driver with a max rpm of 4500rpm, im sure the 600 would work OK, im also sure a properely tuned Qjet would be better. The Qjet is a little more than 600cfm. GM used 750s and 780 holleys with good sucess<sp>. On the 455 im sure there was no hesitation or bogginess with a 600cfm carb, but there was a few HP left on the table.(IMO) Maybe im just out of touch(with pure street) tunning.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
08-02-2004, 12:52 PM | #27 |
the 1000cfm 4150 hp series aint useless on my street driven 468
08-02-2004, 04:42 PM | #28 |
Resident Young Old Dude !
Geeeze Guys, This guy needs help and ya'll all want to argue.. AND WHOEVER SAID A 4x4 CAN'T BE FAST
There is NO WAY to tell what a cam is in a motor, You need to get ahold of the previous owner and or builder and find out what you have. Or take it out and put a Mic on it. and that's a lot of work. Some cam companies do put markings on their cams though and that makes it much easier... From what your typing, it sounds like the cam is too Radical, ( IE: Lopey sound ) SO it's going to depend what you want ??? Are you towing ? If so you'll want to change the Cam, Are you doing some 4 wheel off roading ? I would change the cam also then,,,, But if none of these things are the case and you just like the looks of a 4X4, Then you can go to a 2400 to 2800 Stall convertor, and tune that carb. Yes there are formulas for generalization of carb size, But in those formulas, it doesn't cover Heads, or Valve sizes, or compression ratios, headers or not, or exhaust pipe size.. you will want the smallest carb that will give you good throttle response. but yet allow the motor to receive enough fuel throughout the rpm range. And that requires some fiddling and or a Fuel-air ratio gauge. The fuel ratio gauge will take all of the guess out of it. A 600 to 650 CFM on a small block "USUALLY" does the job for torque. To build Torque, You want Higher Static compression. 1:94 valves, They breath very well up to 5000 RPM, small tubed headers, and good flowing exhaust. (There's always an exception, and I'm sure someone has built a torque small block that will out pull a Deisel and did it way different then this.) The cam I have in my Torque Motor is split duration, 272/282 and Lift of 442/465 I'm also using an Off Road/Towing Convertor. a 600 CFM Edelbrock, small tubed headers, 2-1/2" exhaust with Glasspacks exiting at the rear, A blueprinted distributor, 12 degrees initial advance with 32 full advance coming in at 1000 RPM. pertronix ignition with a Jacobs Omni pak. 410 rear gears, with 32-12/50 tires. I pulled a four horse trailer up hills very well, and could go to the Desert and Rock crawl..10 to 12 MPG unloaded depending on my foot, and it dropped to 8/9 loaded. |
08-02-2004, 09:58 PM | #29 | |
Geared for Collision
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB 1970 C/K20 3/4 Ton 1996 Collectors Edition Corvette 1977 Corvette Coupe |
08-03-2004, 07:23 AM | #30 | |
For what the Cam is intended to do, And what I was doing with it,,,,,,It's great.. The Motor would really surprise me when It would have to really grunt.. But It runs out just above 5000 RPM. But then, that's what it's supposed to do.... |
03-07-2018, 04:18 PM | #31 |
Re: engine guys, need more torque on 383 stroker
I have a similar problem with my '72 2WD C-10.
I built a 383 years ago (I was 15 and thought I was tough but really just dumb...), and it has always just been way too revvy and high-strung for a street truck. Here are the basics of the build: 800cfm Edelbrock Thunder series Carb Weiand Team G Single Plane Intake manifold World Industries heads with 220cc intake runners, 64 cc combustion chamber - I think it is running 10.5 to 11:1 compression... Crane Cams Flat tappet hydraulic cam - Advertised Duration 294/300, Lift .502/.516 1.6:1 Roller Rockers MSD Ignition Headers with 3" true dual exhaust and LOUD mangaflow? mufflers I'm running the stock SM465 Muncie with 3.73 posi rear end, and it is just really boggy and hesitant below 3,000 RPM. I have it rev limited at 6,000 but seems like it would rev to 8k if I let it. Here are my initial thoughts.... 1. Run some break-in rockers with a 1.35:1 ratio? Maybe more expensive and difficult than just swapping the cam and keeping the 1.6 rockers, but just throwing it out there. 2. Install a dual plane manifold? Edel brock makes some affordable options. Maybe keep the single plane and run a restrictor plate? 3. More restrictive/quieter mufflers I'm trying to avoid swapping the heads and cam. I live at 5,500' altitude so maybe I can get away with the high compression on pump gas. I've re-jetted the carb per Edelbrocks recommendations and it helped a little bit. I can't run the initial timing any less than ~18 degrees without backfiring/flames coming out carb and/or starting issues. I'm interested to hear any and all thoughts on the easiest and most economic ways to calm this beast down! |
03-07-2018, 06:22 PM | #32 | |
Hijacking a thread is not neighbourly....lol. Seriously tho', start a new thread for your information search. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
03-10-2018, 09:24 PM | #33 |
4:11 gear swap, 2800-3200 stall converter and you'd see a big jump off the line.
Camshafts make horsepower in a different RPM range based on the Stock-to-Performance ratio. The bigger the cam, generally speaking you'll need to have more RPMs to get that cam into it's happy zone. For example, a slight performance street cam will make power in the 1500 rpm range, but a bigger lumpy / choppy cam needs a little more RPM to get it into it's wheelhouse. The Stall converter will allow the RPMS to come up a bit more into that range before your truck starts to pull away from a stop light / dead stop scenario. This is why you feel that power a bit more from a roll now.. Give it that same RPM off the line, it will come on strong there too. This will impact your fuel mileage. Absolutely. But it will give you the bottom end youre looking for. 383 is known to be a torque monster but it just takes it a little time to get wound up. I'd start with a stall, see how you like it. Somewhere in the 2500-2800 RPM range. TCI Streetfighter is a good one IMO.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
03-11-2018, 02:32 AM | #34 |
Do a proper tune up, set up an adjustable vacuum advance unit. Finally tune the carb.
Look here:http://www.crankshaftcoalition.com/w...EI_distributor and again:http://www.crankshaftcoalition.com/w..._compatibility There is a ton of info on here, do a search and see what your particular builds is wanting to produce more power. Its all trial and error, get some basic diagnostic equipment. Its a great learning experience. |
03-11-2018, 04:05 PM | #35 |
You should start a new thread, especially not tagging on one that's 14 years old!
Your heads will be fine with a smaller cam. But for what you want, that's the only way to get there. Move to a cam with around 220 degrees of duration at .050 and move on down the road. You can make improvements with tuning and tweaking, but when the component that dictates everything else is wrong for your goal, it's just wrong.
03-11-2018, 04:22 PM | #36 |
My 383
HP & Torque: HP 420/ FT 450 LBS Compression Ratio: 10.0:1 .480 Intake .486 Exhaust 229 Intake / 230 Exhaust duration @ .050 Ignition Timing: 34 degrees total at 3500 RPM ...
Stan 67 swb BLU MULE posted via flip-fone |
03-11-2018, 08:10 PM | #37 |
Post Whore
Some things he can check is compression and vacuum. By doing a compression check knowing he has a good engine could reveal that the cam has a bunch of overlap that is bleeding the compression off at low rpms. If that is the case a set of bleed off lifters like Rhoads may be helpful. Checking vacuum at idle and just off idle will add more information to the cam puzzle.
Checking distributor advance curve will be good information to have. Get ahold of an adjustable timing light and a tach/dwell meter (if you don't have a tach installed). Disconnect and plug the vacuum advance port from the carb. We don't want the vacuum advance skewing the numbers. Start by checking timing at idle and write the number down. Then check it 200 rpms higher and write the number down. Continue in 200 rpm increments writing the numbers down until you get no more changes. Obviously having some help makes this much easier. Once all the numbers are recorded you can see what is going on (Put it on a graph if it helps.). These may reveal the mechanical advance is stuck or too slow of a curve is installed for the modifications done to the motor. Once these numbers are obtained then a plan of action can be formulated.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
03-11-2018, 09:01 PM | #38 |
03-11-2018, 11:16 PM | #39 |
Who Changed This?
Put a blower on it. Problem solved. Blowers tame a cam like nothing else, and give you instant torque...assuming that the rest of the stuff you can do has been done. The blower will add some tuning requirements, too.
