#26 | |
yeller
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#27 |
Insert Witty Text Here
I flushed my A/C system and put in a new (not rebuilt) compressor and replaced the orifice tube. I got it vacuumed down and filled last night, but it isn't as cold as I would like it. I'll have to see if I can get some more R134 into it.
It feels good to be working on the truck again. I have been unable to walk for the last 2 months after a couple of surgeries on my ankle, and I'm just starting to get around again. Everything went to hell during that time, of course, so I have a lot of work ahead of me this Fall... Slonaker |
#28 |
Didn't get a lot done this weekend, but did get the new tires on the back of the dually, went with 235/85-16's to try and get a bit higher gear in it. Pulled a boat 116 miles and got a little over 7 mpg with the AC on - arghh..Boat didn't weigh much either. Might have been a fluke or something, maybe I didn't have the tank full on the last go around, but the MPG dropped some no doubt.
So I increased the tire pressures from 40 to 80 (rated PSI) may that will help some. Pisses me off that it got around 10 before I put new plugs, cap, rotor, fixed the exhaust leaks and unhooked the air pump junk. Do you reckon that air pump would have made any difference in gas mileage? I leave Wed. on a 1400 mile round trip with the Dually pulling the race car, it's sounds like it's going to be an expensive trip! Truck seems to be running fine, not missing or nothing. I might try and crank some more timing in it to see if that will help some.
1972 C10 Daily Driver Project Truck 1971 Nova 9 second Tire Fryer 1988 Burb 1987 454 Dually Crew Cab |
#29 | |
Signals in the bumper.
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link |
#30 |
Nothing but mow the yard and a little work on some base boards in the house. I was a Lazy POS all weekend.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
#31 | |
Paul 1984 Chevy C-10 *LWB/305* |
#32 |
That tube is in the line that goes to the lower part of the AC case
#33 | |
Slonaker EDIT: Beyond types too fast! ![]() |
#34 |
DAMN, I love Big Blocks!
What's the difference between an r-12 orifice tube and one designed to run with r-134? Any? Coming from eastern Canada (where it rarely get's over 90), I'm not to adept with A/C systems. The 105-110 degree heat here is making me want to learn, though!
Marc Bona Hobbs, New Mexico 1976 1/2 ton GMC High Sierra. 454 c.i.d./ TH400. *Soon to get a mild warming over.* 3.40 rear. ![]() |
#35 |
Thanks, I'll take a look when I get home from work.
#36 |
Got my temp gauge to work. I had already re-run the wire from the firewall to the sensor which didn't fix it, so i took apart the dash and found that one of the contacts had pulled away from the circuit board. So I tested it by grounding it, then ran it for 20 min idle and took it out a few blocks. It moved a little, but not a whole lot. What is the avg temp of a 350? This is a 77 GMC High Sierra. The gauge runs from C to H. It just got a little bit away from C...
like not even a quarter of the way. Replace sending unit? |
#37 |
working on a new ceiling in the kitchen
have been looking at the vegetables in the garden , to hear them growing ![]() did nothing on the Burb , too busy drove "Ye Old Reliable" to the LPG specialist last week , to put a brand new installation , as the gas prices are again rocketing sky high ![]() the difference will be tremendous , it will cost me the third of what I paid for regular unleaded 95 gas price to pay for the installation : 1350 € but it would be a full benefit after 10000 miles I'm waiting till the car is done , to go to Normandie , in France , on vacation with the kids and my girl friend waiting also for the APOW meeting at Antwerp the third weekend of august , 2500 american cars on one parking , it happens only once in a year Cheers the Baron
1982 Suburban 2WD , 260ci Olds engine,TH400 , will get a 1979 front clip , might be ready in ... 2016 1985 Chevy Van ( 305/350 ) , "Kellogg" equipped , my actual D.D. 1960 Girl Friend , frame still good , body has some dents |
#38 | |
Slonaker |
#39 |
I started the weekend projects early on Thurs night. I finished the new radiator install @ work ($120, 3-row, lifetime warr., delivered to me) & decided to go by Sears after work to pick-up a new battery (it's been slow starting the last couple of days).
I got a new battery & after installing it.... it wouldn't start @ all (yes.... the battery was confirmed good). I wound up trailering it home & had to swap the starter out. What's the typical number of shims required when shimming a starter? I guess I've always been lucky (those who know me will laugh hardily @ that one) & never had to shim a single starter in my life. I started w/the thinnest shim, then to the next thickest, & now have the 2 thickest shims stacked but it still is noisy to me. What do you guys think? Other than that.... I've just been trying to plan my strategy of maximizing my garage space when I start moving everything next weekend. Oh... hey what are you guys doing next weekend? I know where there'll be some cold beer & hot pizza ![]()
#40 | |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#41 |
Tonawanda 454
my project will come next weekend when i get my new Edelbrock 600cfm for my stock 350.. i will keep yall up to date when its done
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! ![]() 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- |
#42 | |
The noise is just a 'whining' sound as it starts.... not really a 'destructive' sound, just louder than it was (or should be).
#43 |
I managed to get a nice radiation burn from my 8 hour welding session on the frame. Next time wear long trousers and not shorts
#44 | |
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
