Old 09-17-2004, 02:34 PM   #26
MrShelley
Too Many Clubs Club
MrShelley's Avatar
Originally Posted by N2TRUX
I can't say anything bad about the other guys, but I can tell you the extra money spent with Air Ride is worth it to me. They are a top notch operation with a quality product.....
Cheaper is not always better.....
By the same token, expensive doesn't always mean better quality. I'm not knocking AirRide...Brett is a great guy and they make a great product. But when quality is equal (as is the case here), I'll take the less expensive option. Of course, if you're happy with AirRide, by all means stick with them. They do make nice stuff, no doubt about it.
AirRide does have that sweet BigRed Air Valve I like. I'll be ordering it from them unless I can find a comparable piece (or have my own made).
And to answer the question about brackets for the rear of a coil spring truck, the answer is no. Drill two mounting holes on the frame, enlarge the hole where the spring bolted on, and bolt the bag in place. Of course, AirRide sells a bracket kit if you want.
How I installed my air bags...
MrShelley is offline   Reply With Quote
Old 09-27-2004, 10:38 PM   #27
guitarornothin
RUNN over AGAIN!!!
guitarornothin's Avatar
Nice Kit! And Cheap Too!
67-72 TRUCKS ROCK
70 SWB shaved and a 72 front clip.and a poly tank.
Peep mirrors and a BIG BLOCK 468 in the making.
XNXNXNXNXNXNXNXNXNXNX
,/. EMAIL ME HERE!, Dont pm me please
guitarornothin is offline   Reply With Quote
Old 09-27-2004, 10:56 PM   #28
Alvin
Never Done?
Alvin's Avatar
Going with the $60 bracket/cup combo from suicidedoors, which should I order? Single port or dual port? I'm really that clueless on this. Thanks
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 09-27-2004, 11:48 PM   #29
BigChevMan
My Thoughts Exactly!
BigChevMan's Avatar
That directly relates to what bags you buy. Airlift has a dual port bag which means that you can feed two airlines to it if you wish. Single port means that only one line will feed the bag. The benefit of having dual lines is that you can run one as a fill line and one as an exhaust line. Not sure if it's worth the price. single port is probably what 95% of all bag systems are comprised of.
BigChevMan is offline   Reply With Quote
Old 09-28-2004, 02:29 PM   #30
luckydog
< Fav Place on Earth!
luckydog's Avatar
imo, dual port is kinda dumb because you can just run a Y adapter. I dont think its worth the price either. Single port with the Y doesnt make your system any slower because youre either going in, or your going out.
Horsepower is how FAST you hit the wall, torque is how HARD
luckydog is offline   Reply With Quote
Old 09-28-2004, 03:33 PM   #31
BigChevMan
BigChevMan's Avatar
plumbing it that way...it doesn't make a difference...however if you run two fills...one for each port of dual nitrogen bottles it'll hop the front end a couple feet off the ground...if that's your thing.
Old 09-28-2004, 03:43 PM   #32
Alvin
Never Done?
Alvin's Avatar
Okay, thanks guys. Definitely not interested in hopping. Cruising the strip is fine with me. Guess I'll go order me a set.
Old 09-28-2004, 09:30 PM   #33
luckydog
luckydog's Avatar
BigChevMan- Yea thats true... I wasnt thinking about nitro or hopping.
Old 10-05-2004, 03:45 PM   #34
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
classic performance products has some reasonably priced kits as well
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 11-04-2004, 07:04 PM   #35
omar69chevy
hey mr. shelly
i just got the kit for the front but i cant seem to figure out how it goes can u help me out on this asap thanx, omar
omar69chevy is offline   Reply With Quote
Old 11-04-2004, 09:00 PM   #36
GreyHoundSteve
I am also interested in more info on bags. My truck is badly in need of new suspension and ive been torn between a static drop, coilovers and bags. I understand static dropping and have done it many times before on cars but ive never had to drop a car 6" inches so im new to the bags and dont really understand them at all, is there a place where i can get info in lamens terms?
Also, i live in DFW TX and i noticed that a few guys on this thread are running bags on their c10's near me ..... would any of you be willing to let me check out your truck and take a ride with you?
GreyHoundSteve is offline   Reply With Quote
Old 11-06-2004, 12:30 PM   #37
SCOTI
SCOTI's Avatar
I'm close, but my truck that has bags on the rear is not able to drive (so I can't offer a test drive). I can help w/installation issues if you need though.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-06-2004, 01:35 PM   #38
GreyHoundSteve
Is the air bag system fuctioning or is the truck apart? I would like to just see a sytem on these trucks in something other than a picture and talk to someone who can explain what all is involved in setting one up and maintaining it. If your willing to let me come check out you system i would love to come see it.
Old 11-06-2004, 02:22 PM   #39
SCOTI
SCOTI's Avatar
No, the truck is put together so you can see how it all works. I just can't give you a test ride. I can give you a ride in my 74 to give you an idea. It's close . . ..... just not as good as my 68, + the 68's rear suspension is adjustable for weight increases.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-06-2004, 10:12 PM   #40
GreyHoundSteve
Hey scoti, i'll pm you about coming out to take a look sometime. Bags seem like the way to go for sure in the rear and if i can figure it all out i might just bag the whole thing.
