Old 09-13-2004, 04:42 PM   #26
Jakes-66-K10
Jakes-66-K10's Avatar
What are they called though, so I can search ebay for them?
Jakes-66-K10 is offline   Reply With Quote
Old 09-15-2004, 04:43 PM   #27
Jakes-66-K10
Also, do you need a specific porportioning valve for disc brakes? I'm swapping front ends with a '71 and it has discs, master cylinder, and valves but no booster. So, I found a booster in a junk yard today that can bolt up to my master cylinder, but i'm not sure if the porp. valves will work with them both.
Old 09-15-2004, 04:54 PM   #28
FormerMember
http://motors.search-desc.ebay.com/C...chedZ2QQsotrZ2
FormerMember is offline   Reply With Quote
Old 09-15-2004, 05:03 PM   #29
Warbones
Navel Inspector
Warbones's Avatar
Nice truck, looks to be pretty clean. I always have liked the color green too.
1948 Chevy Aerosedan GONE! I think.
1984 Cadillac Fleetwood Brougham Coupe
WANTED 1967 IMPALA
1967 CST C10 Long Bed with a 283
Warbones is offline   Reply With Quote
Old 09-15-2004, 05:34 PM   #30
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Same prop valve for power and manual, as long as it's disc brake truck, it will work.
Old 09-16-2004, 04:10 AM   #31
70C/20CHEV
I agree with tx firefighter on brake proportioning valve, as long as its a disc brake proportioning valve you should be ok. After checking over 30 different parts catologs it doesnt seem to matter if 1/2 or 3/4 ton and 1971 and 1972 are the same. My used disc brake set up had the proportioning valve with it (3/4 ton). My 1/2 ton parts doner truck appears to have the same proportioning valve on it.
70C/20CHEV is offline   Reply With Quote
Old 09-28-2004, 04:05 PM   #32
Jakes-66-K10
Does anyone know if they make rebuild kits for master cylinders? Here's a shot of my original, and then the new cylinder that came from the '71 donor with discs. It's not a master cylinder I've ever seen before, with a weird ruber gasket inside. Wondering if I can rebuild this or have to use it as a core to order a new one?
Old 09-28-2004, 04:10 PM   #33
Jakes-66-K10
And last question for today, here is a powerbooster that was from a 71 or 72 blazer. I haven't seen rebuild kits for these either, wondering if there is a way to know if it will hold pressure or not. I can see what I think has been a wasp nest inside the vacuum port, do you think it's safe to flush this out somehow and still use it?
Thanks everyone!
Old 09-28-2004, 08:17 PM   #34
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i think i read that master cylinders are not worth rebuilding, cause they are only 25 bucks. cant help with the booster i have the same question.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 09-28-2004, 08:28 PM   #35
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
[Sure wish the search feature was working so people like me aren't asking the same questions over and over...[/QUOTE]
I think he is gettin close. I just searched the FAQ's!!!
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 09-28-2004, 08:31 PM   #36
chickenwing
Thanks for the rim identification guys, that's awesome! I've looked around a bit online to try to find a name, part number, or anything so I can order two rear wheels. Any ideas about where to order these?
70C/20Chev, I sent you a private message about these camper mirrors. I'm not gonna use them.
2nd the ebay thing. I bought a brand new set of 4 with tires for $400.
Old 09-28-2004, 08:35 PM   #37
chickenwing
Should have read all of these and posted once. sorry. Search ebay motors for "chevy 8 lug" that should narrow it down for you. Watch this at least a week before you buy. Sometimes after a rush of buyers the sales go flat. That's how I got mine so cheap.
Old 09-29-2004, 12:53 AM   #38
cheyenne10
cheyenne10's Avatar
master cylinder
Master looks identical to my original one in 72 C20 with power discs. New one I bought for $18 looks identical (had $8 core also which I got back). Almost certain that is right master for c20/k20 with front Power discs. Your booster looks rough. I know there are services that rebuild these. Last one I read up on required parts to be dipped/stripped of finish and grime before sending in to rebuild. I am still reseaching the competition on rebuilt boosters. I am looking to refinish one I have and replace exterior boots to make look new, no luck on parts source yet. I am just finishing up replacing master and booster with restored one I bought for another truck a year ago. It was on shelf and saved me time finding parts for used one. I will try to restore myslef and use on 2nd truck. I am going to start a post on problems during install looking for bleeding help.
Good luck. Power brakes are way better than manual ones!!
Bob
cheyenne10 is offline   Reply With Quote
Old 09-29-2004, 02:08 PM   #39
Jakes-66-K10
Where are you guys buying Mast. Cylinders for so cheap??
Old 09-29-2004, 02:22 PM   #40
FormerMember
Kragen's here.
Master Cyl was 18.00
Booster was 72.00
Same ones you have pictures of.
Go 71 3/4 ton when you buy them...
Old 09-29-2004, 02:28 PM   #41
Jakes-66-K10
Is that a local salvage yard or something? I was hoping to find somewhere I could order online for that price...
Old 09-29-2004, 03:13 PM   #42
chickenwing
www.partsamerica.com this is the checker autoworks/Kragens online partner.
Old 09-29-2004, 09:16 PM   #43
Tx Firefighter
Pep Boys, O Reilley, AutoZone, just about any generic chain store will have them for 20 bucks or so.
Old 10-05-2004, 11:34 AM   #44
Jakes-66-K10
You guys rock, my local Checkers has them for $15.99. That sure beats the $50-100 the catalogs charge for these... that's a big difference. I took off the rotors and spindles from my donor front end over the weekend. I'm hoping to put these spindles onto the '70 arms. If for some reason I need to replace ball joints, should I put the '70 ball joints or the '72 ball joints in these arms?
Old 10-05-2004, 05:21 PM   #45
Jakes-66-K10
Two more questions: what is everyone using to paint bare metal parts? I am thinking of painting the new master cylinder, booster, hood hinges, etc. POR15 seems overkill for these, I was thinking just paint in a spray can?
And last question for the day, does anyone know of a source to buy new CST/20 emblems? I've literally checked dozens of places, and can only find CST/10 and Custom/20 badges... there has to be someone who has these.
Old 10-05-2004, 07:46 PM   #46
68w/sbc406
68w/sbc406's Avatar
i just use high temp VHT spraypaint. it matches the semi gloss that i painted the engine compartment pretty well
Old 12-03-2004, 03:17 PM   #47
Jakes-66-K10
Well, just a quick update. I have this small block 400 in a machine shop, and have replaced the block, reusing the crank, and ordering new pistons. I did find out that the heads on this engine are not reusable. Any advice for replacement heads, from reading on here I have heard good things about Vortec heads. My intent is to build a strong and reliable motor, that is above average or stock specs. I won't be racing, but some trailer towing, and fuel consumption is important too. I could use as many suggestions as possible, such as heads cams pistons etc.
I have found a set of 400 heads for only $50, but will spend extra to go to Vortec heads if it makes a big difference...
Old 12-03-2004, 03:23 PM   #48
Dean
Dean's Avatar
All of that blue paint on the engine is a tip off to being a newer engine. Late 70's is when they were blue I think. At least I had a 79 Vette that was blue.
Dean is offline   Reply With Quote
Old 12-03-2004, 11:55 PM   #49
68w/sbc406
68w/sbc406's Avatar
i plan on putting vortecs on my sb400. just make sure the steam holes get drilled or you will have some problems
Old 12-04-2004, 12:15 AM   #50
Jakes-66-K10
Yeah that's what I hear. So far the cheapest option I have seen is Summit, they sell the vortecs new for just over $500 for the pair...
