#26 | |
i know what u mean adding a fuel cell/tank to the back doesnt make much difference, especially when there is no bed.
68 short step, 406/700r4, 9" w/discs. |
#27 |
Keep On Truckin'
That's exactly what I am in the process of doing with my '72 with the same set up on a rear leaf truck, including the aluminum FCG tank. I too bought a wrecked '87 Camaro to get the TPI set up. Could I get you to send me the dimensions from the back of the frame rail to where you positioned the fuel tank? Did you remove the cross member in front of the gas tank so you could slide it forward? Thanks and great job!!!
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
#28 |
mocwon
I can get you dimensions on Monday, I am at work and we are heading out for the weekend after work. I removed the crossmember that used to sit right where my tank is. The very rear one is in the stock location. I will get you better pics and some measurements on Monday or Tuesday. PM me with any specific requests. Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#29 |
Professional Grade
who did you get to reprogram the chip for you, and what kind of thermostat housing / hose did you use? I just found out the 86 computer I bought might be a 305 computer... The only difference between 350 and 305 is prom, so I figured maybe I could get someone to set me up with a 350 prom...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
#30 |
Back in the sticks
Looking good! Hope the rest of your mods go as well. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty Last edited by red71cheyenne; 10-04-2007 at 08:36 PM. |
#31 |
blood type; Retumbo
Shawn did a good thing going with the MAF set-up as opposed to the speed density. maf will work better with a larger cam or other mods. it bases the fuel & ignition curve on the quantity of air going in. the problem is in the intake ducting. its gonna take some creativity & possibly an elec. fan to make room for it all, but hey, thats more fun I think.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
#32 |
Nice...!
I have a set up out of a 87 IROC sitting in my basement. Maybe it's time to install it. ![]() Great job, thanks for the post. |
#33 |
Ebay Junky
71swb4x4- what did the swap cost you total?
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain.. 1983 Chevy c10 swb 2wd - possible 350tbi supercharged... |
#34 |
blood type; Retumbo
not as much as I would have liked. I didnt even get one single beer for my help.
#35 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I found in my swap that the Injected T-stat housing was smaller than the Non-injected T-stat housing.I tried to use my orig. T-stat housing but it ended up pionting the wrong direction and interferred with the throttle linkage.
I found this one while a desk person at Car Quest let me look through his books. Here's the Car Quest part number of the thermostat housing. The application is for a 64-78 Chevy truck with a 327ci engine. Useing this T-stat housing will allow the use of you orig. upper rad hose.It's a bolt on swap. ![]() Here you can see the difference between the two. ![]() I migged a bead onto some aluminized pipe and made my own upper rad. hose after a while though.A little cleaner look I think.I just cut up my orig. upper rad hose and used the different angled pieces to make that new upper rad hose. ![]()
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 10-27-2004 at 10:08 AM. |
#36 |
Formerly yellow72custom
For those with running TPI, how were the increases in fuel mileage, driveability, cold starts, and power? I wouldn't mind TPI eventually on my truck......EFI rocks!
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
#37 |
Cold starts are as expected with fuel injection.Rev's high initially on startup but settles down to about 1000rpm while warming then gradually idles down to whatever you've set your min. idle at.(approx. 600-750rpm).
I noticed a 50 mile increase in my milage.I have a stock 21-22 gallon tank and got approx 50 miles extra to my tankfull.That was highway and with my 700R4 working as it should. Low end tourque is awesome.No stumble off the line at all. It does peak out,as far as power goes,around the 5000-5500 rpm mark but that's what it was designed to do. Stock TPI is not meant to be used in a high reving application. Here's my TPI in my 71 Blazer. ![]()
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 10-27-2004 at 12:42 PM. |
#38 | |
I know what your thinking.......I have ESPN. ![]() Sometimes it's easier to do things the hard way. ![]() Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! ![]() ![]() |
#39 |
Ebay Junky
do you have to run dual electric fans?
#40 |
This is a swap i defintely want to make soon. I had an 86 Corvette about 8 years ago and it was a dog when i bought it but after a few simple bolt on mods (and removing the cats) i was dusting mild LT1's. I really like the TPI set up. It is easy to work on and VERY SIMPLE.
I was wondering if one you you guys who have done the TPI swap on an older motor could post a detailed description of everything required and problems you incountered. I know there is about 20 threads on this board and everyone links that one guys site but surely there is someone here who documented their own swap to tpi? One question i had was about the distributor. Mine just went bad on my 350 (carb) so i ordered the msd dist and set for around $300 but now im sure i want to swith to tpi within the year and was wondering if i would be able to use this dist with a tpi set up? |
#41 |
Nope.If the one you bought has a vacume port on it.Tpi uses the ECM to advance and retard timeing.It's all done electrically.
Yes I run two 14" Perma Cool electric fans. I used to have an aluminium shroud but I have since changed it and welded up a new one. old one ![]() new one. ![]() You can see the TPI swap as well as all the other projects I've done to my Blazer in the link below. Here is a link to ALL the pic's during my conversion. Click HERE
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
#42 |
WOW, that a great site..... LOTS of info.
#43 |
Professional Grade
When I eventually get the rest of my parts that are in the mail, I'll be doing a photo documentation of everything I end up doing to install it.
#44 | |
This board is GREAT! |
