Old 09-05-2004, 08:53 AM   #26
SLS
Finish the'71..or bust!
SLS's Avatar
"Also when I turn on my right blinker my high beam indicator flashes and when the high beams are on you guessed it the right blinker lights up"
You mean they are not supposed to do this??? Mine has done this since the day I got it....but I won't even go into the 'engineering' that I have found in the wiring all over my truck...LOL. Let's just say a fire extingusher is a manditory 'option' in my cab...heh heh heh...........
SLS is offline   Reply With Quote
Old 09-05-2004, 10:25 AM   #27
Orange70chevy
Orange70chevy's Avatar
Originally Posted by jay6891
Orange70chevy, check your grounds to the instrument panel, sound like you have a bad one.
Where and how are they grounded
Orange70chevy is offline   Reply With Quote
Old 09-05-2004, 01:13 PM   #28
jay6891
Car Knocker
jay6891's Avatar
It is grounded through the printed circuit board. You will have to pull the cluster. The screws that hold the board to the back of the cluster will have a little copper ring around them. Take the screws out, and carefully with a wire brush polish them up along with the base of the screws. Take out the bulbs and do the same. I did this along with running a little insurance with another wire going to the cluster tied to a good ground fixed this same problem. While you have it out look at the circuit board for any breaks in the copper in the ground curcuit. It will be the only one that goes to ALL lights and screws that I mentioned. If it is broke get a new board or run jumper wires from each section of the instrument panel.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 09-07-2004, 02:12 AM   #29
smbrouss70
smbrouss70's Avatar
My PO had a 5th wheel hitch mounted in the bed of a 1/2 ton SWB?! The bed was damaged and repaired by drilling holes, slapping bondo on, covering with masking tape to smooth the bondo because he didn't want to sand it, then painting it. and OF COURSE the wiring is f@&ked.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 09-08-2004, 02:19 PM   #30
Dean
Dean's Avatar
I've had a house light switch controlling the heater. duct tape holding the fresh air vents shut, house shag carpet, expandable foam rust repair, one owner definitely liked to braze....lol
Dean is offline   Reply With Quote
Old 09-09-2004, 11:47 AM   #31
68stepsidec10
i bought my truck off my uncle and he bought it off my dad but it has been off the for 14 years i pick it up on Sun so i'll see what it really needs
68stepsidec10 is offline   Reply With Quote
Old 09-09-2004, 03:03 PM   #32
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
My 72 has absolutely no rigging from previous owners. All gauges worked excpet thew temp gauge. I have put in a decent set of mechanical gauges so I don't care about them anyway. Only problem it has electrically is the left turn signal light comes on and stays on when the lights are on. I know its a ground being bad and feeding back, but the turn signals work fine so I'm not going to worry about it, its just a work truck. Mine still has the radio delete plate installed and looks to never had a radio installed anywhere else. All the wiring looks factory. The engine was very clkean inside but the cam had one flat lobe and two more half gone and the timing chain was flopping around and the gears had bad wear marks from the chain. I know its all original to, numbers match and the only thing that appears to have been removed on the engine was the intake. Don't know why, maybe to replace a lifter after it flatened a lobe the first time and the owner didnt want to replace a cam. It did run ok like that but had a tapping noise.
I have worked as a mechanic so I have seen all kinds of crap like posted above. House switches in cars, vise grips over a brake line to seal it off since the owner didnt want to fix a rusted line or wheel cylinder, house wires to install whatever, screws or whatever else they could find to plug holes with, RTV to plug up leaks in the radiator, real crappy flex pipe for exhaust hung with all kinds of wires, stop signs for body repairs, fiberglass floors, you name it I've probably seen it.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 09-09-2004, 05:48 PM   #33
Dick Dale
Excelsior, You Fathead.
Dick Dale's Avatar
I feel lucky. The only thing I have found so far is the cigarette lighter was spliced with duct tape and the homemade manual choke cable runs through a spot under the heater vent. I will change that.
Go Navy. The Sea Is Ours.
Budget 350 Build
http://67-72chevytrucks.com/vboard/s...38#post2264638
Dick Dale is offline   Reply With Quote
Old 09-09-2004, 07:45 PM   #34
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
my friend bought a 77 swb and there was expanda foam holding up the rusted out battery tray. he got rid of all of that when he 'found' a tree
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
