Old 09-06-2004, 11:38 AM   #26
bigjimzlll
bigjimzlll's Avatar
im running a solid roller and 12.8-1 compression. big dart heads..a 5000 stall and 4.56 gears
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 09-06-2004, 12:11 PM   #27
406_SBC
406_SBC's Avatar
hey "bigjimzll" your truck has ran pretty much exact same as my Dads truck that he sold last year. His best time was a 11.80 on pump gas, I don't remmber the mph i'd have to drag out some old time slips to see. Do you have any pics you can post???Heres a pic of my dads truck.
" Oh you didn't hear did you. You hear I got a shotgun pulled on my ass? Swear to God."- O'bannion
406_SBC is offline   Reply With Quote
Old 09-06-2004, 12:38 PM   #28
bigjimzlll
bigjimzlll's Avatar
http://67-72chevytrucks.com/vboard/s....php3?t=115767
Anderson,CA
Old 09-06-2004, 05:35 PM   #29
skid
Originally Posted by 69GMC910
So lets just say I assemble my 355 with the XE274 cam, 1.6 roller rockers, Performer RPM 64cc heads, RPM Air-Gap Intake , and leave the bottom end the way it is, (10:1 Flat tops). What can I expect this engine to produce??
Also the XE274 is a .490 lift cam, correct me if I'm wrong but with the 1.6 rockers, will my lift actually be .523???
And if so, with this combination should I be worried about piston to valve clearance??
I had that set up in my 3200# Vette with 1.6 rockers and could barely get under 14 seconds@ 100 mph in Calgary (3500 ft elevation 6500 ft air density). The only thing different was my intake which was a 7530 Weiand intake and a 4 speed M-20.
Built a mild 406 with good heads (AFR 210's), slightly smaller cam (222/230), and same intake and now run low 12's at 115 with the same air. Traction isn't an option...406's ROCK! The engine does need more cam though, it runs out of breath early at ~5300 rpm. It dynoed at 476 hp and 496 torque.
Toys:
72 K5 Blazer
74 Vette
skid is offline   Reply With Quote
Old 09-06-2004, 07:37 PM   #30
browndawg71
if your on a budget like i know i am ,might think about a 400 with vortec heads ,small solid lift cam, performer rpm airgap, roller rockers. put a cam bout like the comp 292 in and a 3000 stall and it will haul booty. of course there is always big blocks.
browndawg71 is offline   Reply With Quote
Old 09-06-2004, 09:00 PM   #31
69GMC910
MOTORHEAD!
69GMC910's Avatar
Excuse my ignorance, but is a 406 just a 400 bored .030"
910
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 09-06-2004, 09:32 PM   #32
skid
910
Yup!
Toys:
72 K5 Blazer
74 Vette
Old 09-07-2004, 12:17 AM   #33
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i read in a book that the cubes actually come out to 407 but i never heard anyone say they had a sbc407
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
