#26 |
I got one made, and got the alternator all tightened up. Now, no more belt squeak..but the headlights still flicker a LITTLE at idle. I'm going to do some testing and figure out where my wiring is messed up at.
#27 |
![]() Join Date: Apr 2004
if you get a smaller pulley on your alt it will turn faster and at idle and will kick on much sooner. if you are having problems at ~700 RPM and not at ~1000 RPM This should solve your problem. Or If the alt has a warranty, you could explain your problem and they may give you a new one. The new one may or may not kick on sooner. Good luck.
#28 |
DAMN, I love Big Blocks!
Tim, I think others have said this before, but CRANK UP YOUR IDLE A BIT!
Marc Bona Hobbs, New Mexico 1976 1/2 ton GMC High Sierra. 454 c.i.d./ TH400. *Soon to get a mild warming over.* 3.40 rear. ![]() |
#29 |
Yeah but then it wouldnt sound like its camming
#30 | |
http://www.lislecorp.com/tool_detail.cfm?detail=37 ![]() 12400 Fan Belt Tightener Makes Belt Tightening an Easy, One-Person Job. Works on most alternators and some other belt driven accessory units. 1/2" square drive. Shipping Weight: 9 oz. Suggested Retail: $ 8.95 UPC Code: 083045124009 ![]() ![]()
Semper Paratus |
