Old 10-08-2004, 02:24 AM   #26
Alexis
Member since 2000
Alexis's Avatar
Originally Posted by jugernot
I have been thinking about getting a welder and found a craftsmans. What do you think of this one.
http://www.sears.com/sr/javasr/produ...&bidsite=CRAFT
Go with a lincoln or hobart before a craftsmans. I say hobart over lincoln though.
Alexis is offline   Reply With Quote
Old 10-08-2004, 02:28 AM   #27
GSFMECH
On the road
GSFMECH's Avatar
Miller 135, I love that thing. I hear that the cheaper ones use an aluminum wound transformer and the bonafide Millers use a copper wound one. I like the fact that all of the rollers and stuff in it made out of metal and not plastic like some of the cheaper ones. Maybe someone can shed more light on this that knows more about it than me.
Mike
Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos
72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works.
My new build thread "Castro"
https://67-72chevytrucks.com/vboard/...d.php?t=820934
My old build thread, the blue truck
http://67-72chevytrucks.com/vboard/s...d.php?t=271489
www.louisianaclassictruckclub.com
GSFMECH is offline   Reply With Quote
Old 10-08-2004, 02:44 AM   #28
ZOOMY
welder
Lincoln SP 135 here. Perfect for sheetmetal work.
ZOOMY is offline   Reply With Quote
Old 10-08-2004, 04:11 AM   #29
68LSS1
68LSS1's Avatar
I too got the Lincoln 135 w/regulator, Stargon, etc. I really like the unit I just wish i had went ahead and gone up to a 220 unit. If body work is all you'll ever do a 110 will be fine plus it's easily portable but if there is a remote possibility that you may want to do some suspension/frame stuff later on, save the extra money and get the 220 unit. Doesn't matter which brand (when talking about the 110/220 abilities).
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 10-08-2004, 04:38 AM   #30
BrianJordan
Iron Thunder
BrianJordan's Avatar
i use a chicago electric ez mig 110/1 fluxcor for body work and lincoln 225 amp. for hevy steal.
BrianJordan is offline   Reply With Quote
Old 10-08-2004, 05:15 AM   #31
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Got a Lincoln 100HD, need to buy the gas conversion kit. But Hey it came with 12lbs of flux core.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 10-08-2004, 07:59 AM   #32
I also have a Lincon SP100T. I got it on line from these folks.
http://www.weldingmart.com/
It was factory reconditioned and same warrenty as a new one for half the price.
Works real good for the body work and stuff that I need.
Old 10-08-2004, 08:03 AM   #33
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
I have a Hobart 135 MIG, a Miller 210 MIG, and a Miller EconoTIG.
I started using the Hobart 135 for sheetmetal work, but have switched to the TIG and love it!! The weld area stays much cooler and I can hammer and dolly the welds easier to keep flat panels flat.
One of the things that I found that makes welding sheetmatal easier with a TIG is to use 1/16" tungston, and for filler rod, use regular .035" MIG wire. Works great!!
I use the Miller 210 for bigger stuff, frames and such. I will be getting a spool gun this month for welding aluminum with it.
Don't use the Hobart 135 much anymore.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 10-08-2004, 10:03 AM   #34
bucket
bucket's Avatar
i use a clarke 135en. love it. i think clarke may make the craftsman welder.
bucket is offline   Reply With Quote
Old 10-08-2004, 12:13 PM   #35
mocwon
Keep On Truckin'
mocwon's Avatar
A twenty-year-old Snap on wire feed mig welder with gas.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 10-09-2004, 02:33 AM   #36
69ChevyLB
Active Member
69ChevyLB's Avatar
welder
Anyone heard of Powermate brand? Have a chance to pick one up with cart, gas bottle, etc. for good price.
69 C10 LWB Project
47 Cushman Scooter Project
It is better to have loved and lost than to live with a psycho all your life.
69ChevyLB is offline   Reply With Quote
Old 10-09-2004, 02:40 AM   #37
SLS
Finish the'71..or bust!
SLS's Avatar
Lincoln SP 135 Pro Mig.
Gas, or no gas....the choice is yours with this machine.
I love it.
SLS is offline   Reply With Quote
Old 10-09-2004, 09:07 AM   #38
ed455
Captain Ed
Clarke 150EN. It's a 220v model and I like it OK. The settings could be a little more variable. There's basically 6 heat ranges on it. I don't know what the amperage on each setting but it always seems I'm a little too hot or not quite hot enough and no setting in between. The lowest setting is a little too hot for sheet metal. I do alright with it and I'm too cheap to replace it. It beats the heck out of the little Chicago flux core I had before it. Once you've used gas, you will wonder how anyone could buy flux core. I was pretty good with the flux core, but MAN!, what a difference the gas makes!
ed455 is offline   Reply With Quote
Old 10-09-2004, 02:43 PM   #39
longnlow72
longnlow72's Avatar
the welder i use is called Fusor......sells for 44 bucks at API.
$44? is it any good? i want to get a welder but one for cheap
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done...
longnlow72 is offline   Reply With Quote
Old 10-09-2004, 03:14 PM   #40
rigo
Flake Daddy
rigo's Avatar
Miller 210 Mig here...with spool gun....can weld anything I would ever need......
rigo
1968 SWB Fleet Daily Driver 350/TH400 shaved driprail,emblems,tailgate,air ride suspension
1964 Pontiac Catalina 2dr. hardtop shaved everything, air ride suspension
1998 Range Rover
1960 El Camino....in the works.....
rigo is offline   Reply With Quote
Old 10-09-2004, 03:26 PM   #41
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
Fusor is the trade name for a metal bonding adhesive. Many manufacturers use it on the assembly line and some repair shops have started to adopt it. Pretty wild stuff, really.
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 10-09-2004, 03:38 PM   #42
longnlow72
longnlow72's Avatar
gotcha
Old 10-09-2004, 03:50 PM   #43
Aubigmac
I have the Lincoln 175 that they sell at Lowes. It was about $600 and it comes with a cart. Already had the bottle. Perfect size for me works well on heavy stuff as well as sheet metal. It wasn't much more than the 110 welders.
Aubigmac is offline   Reply With Quote
Old 10-09-2004, 04:50 PM   #44
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
fusor is like liquid weld....i dont have the money for a welder so i use that. they say it is stronger than a weld...and company offers a lifetime guarantee on it....
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 10-09-2004, 08:51 PM   #45
gmc67swb
gmc67swb's Avatar
Miller TIG.(cracker box). 110vac. Very compact and very portable...plugs in anywhere..The bulkiest part is the gas bottle. TIG welding is like drawing with a pencil.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
