11-02-2004, 11:31 PM | #26 |
blood type; Retumbo
I went to the body shop this morning. I went to school with the owner & my dad used to work for his dad so we know each other pretty good. he also knows what I want.
he said that to help avoid the possibility of them calling it a total loss I should account for everything I have done so far. this is not an easy task as I have changed &/or rebuilt the whole truck except for the body work. (71swb4x4 can attest to this) he said to even figure the book time for all of my labor. just doing the engine & trans rebuild comes to about $3000 in labor alone. I think I will have to borrow the old labor time guide from work when the adjuster comes to visit. he also said to make sure they know that I will not settle for a total loss. (this is my time to be a polite prick) my new question is should I have him straighten the frame or replace it? (from visual inspection he said it was off by about 1 inch) I was thinking that since I have the spare cab then I could set up the new frame & start my "build-up" while driving my lefty. <I call it that since the front is now looking to the left>
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
11-03-2004, 12:16 AM | #27 |
Personally, I would straighten the frame. Shouldn't be hard for the bodyshop to do by the looks of it, not too expensive, and you'll never be able to tell it was bent if done right. That would save you alot of work, not to mention title paperwork if you wanted to legally change the frame.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
11-03-2004, 12:24 AM | #28 |
its all about the +6 inches
if all the damage is in front of the cross member, then I say straighten it.
If it is damaged after the front crossmember, let your paint and body guy answer this one. |
11-03-2004, 01:30 AM | #29 |
I got a 70 chev 1/2 ton frame if you need it. All drum and coil spring,V8/AT 3.07 posi. Let me know if you need it on the cheap.
