#26 |
you will never have any problems with bags as long as they are installed right!! =).. heres some info on equipment
http://www.bagginit.com/facts.html and i know what you mean about dragin and rubbing .. except i did it on purpos!! my old truck ![]() ![]()
98% of ALL fords are still on the road today... ![]() ![]() where is the best place to park a ford???.. next to a fire station!!!! ![]() pictures of my new and old trucks! |
#27 |
The only problem I don't like about the big reds are how slow they are.
#28 |
The duty cycle makes a big difference if you are running a 155 switch and play with it alot plus the 400 draws 30 amps where a 450 draws 23.I am just saying from what I have run into the 400 gets too hot if you run it for long periods of time.
#29 |
Under construction!
I understand what your saying. If you like to hit the switches allot and have 16+ gallons of air storage, an engine driven compressor is the only way to go. JMO though.....
Personally, I feel my BIGRed's and 1/2" air line make for the perfect speed. A rise time of under 2-seconds is good enough for me. ![]()
2001 Silverado bagged on 22's. *Sold* |
#30 |
#31 | |
Happy to be here
![]() Join Date: Mar 2000
My 77 doesn't "pop" up but I wouldn't say it's slow and I'm only running 3/8 line... ![]() Last edited by N2TRUX; 11-20-2004 at 01:34 AM. |
#32 |
Most people I do installs for want their system really fast.I run alot of systems with a line drive,3 7gal tanks,1/2 5/8 ported valves with 175 to 200 psi switch.this is the reason I don't run the BigReds plus the cost of them.I wasn't bashing the valves just saying it boils down to your needs.I know of several people running the bigReds right now and they are not very fast.Then again like I said it depends on what my customer wants.
#33 |
Another thing that can affect the rise/drop speed is the way the system is controlled. I have done a few systems using the Dakota Digital controller and have noticed they are a bit slower in rising and lowering compared to a system with gauges and switches. I am guessing the reason for this is because the controller is monitoring the pressure on the valves and that info needs to go back and forth to the controller to let it know where the pressure is at.
For people that want to play with the system a lot, I usually run the engine driven compressor and large tanks. |
#34 |
what bags work for our trucks I know the firestones and slams mentioned in this thread but what about Airlift and Conti Or are the firestones a better choice I want to go with bags I am not going to have any problems with.
One more question how can you go with a unchopped crossmember and If I chopped it when does the steering box hit the ground |
#35 |
I have used conti's,stones,& airlifts with no problem out of any.I use conti's the most because I can get them faster but you shouldn't have any problems as long as your bag doesn't touch anything.
#36 |
But which bag is It I need from air lift or conti or anybody else
#37 |
I run conti 224.The good thing is conti,stone,airlift,slam all share the same bolt pattern for mounting.
#38 | |
Seņor Member
#39 | |
#40 | |
Happy to be here
#41 |
The RidePro E controller only replaces the switches and gauges to control up/down and raise (to a user programmed level) on start-up, it can also be used via the panel or remotes.
Dakota Digital makes one (twice the price) that has four user presets and a timed bag dump feature, manual up/down, auto mode (continually adjusts bags to desired setting) and a few other features. There is another piece coming out at the beginning of the year that will have the features of the Dakota Digital one (plus a few more) but will be around the price of the ART piece. |
#42 | |
Happy to be here
On my 77 we monuted the gauge in the ashtray... ![]() ![]() |
#43 |
N2TRUX,
how do you control the pressure with that gauge? |
#44 | |
#45 |
Does anyone have a link to a place that sells digital controllers and gauges? I would settle for a link to someone who sells cool switches. Ive gone to GREAT lengths to eliminate the "old school" style knobs and switches and the only toggles ive seen look like they were purchased at a hardware store.
#46 | |
Happy to be here
#47 |
Happy to be here
And mounted it under the seat...
#48 |
Too Many Clubs Club
That switch mount is very trick indeed! The first time I saw that pic I didn't know what is was, but then I was like "ooooh! cooool!"
How I installed my air bags... |
#49 |
turnin wrenches
another thing you might consider is going with the "big red" valves from air ride. they do cost a little more but they are faster than the ride pro set up which makes it nice for quick changes (pothole prevention) i have had both and am really happy with the way the big red valves have performed. i have a 4 corner setup which allows me to control each corner individually preventing the air from rolling from one side to the other. the bigred valves are easy to install one block has both your inlet and outlet for each corner (4 blocks required for 4 corner) and the make it so you can have each block seperated or combined for a clean simple set up. i run four toggles and 2 dual needle gauges however i am planning on going to a digital setup here in the near future.
on a side note: N2trux thank you for helping me convince my buddy crush into bagging his truck, i have been trying to get him to do it for a couple of years now!! his k5 is being sold this weekend so his truck will soon be receiving the bag treatment!!
"three can keep a secret if two are dead" -unknown hell's angel- D.M.C. -FF- 68 SWB full frame off (project ol skool) 2000 s-10 formally bagged but now my daily driver... |
#50 |
Trucker.
I had the ride pro's on my 83 and personally liked them, easier and cleaner install and the speed was plenty for me. I think the fastest valve I would ever run would be a 3/8" SMC/Airlift/GC.
