Old 01-15-2005, 12:52 AM   #26
badpeanut
Not a bad nut after all..
badpeanut's Avatar
I'm installing a dual battery set up similar to the Blazer Chalet, so if parked, the battery can drain, and not affect the engine battery and starting capabilities. Of course, the alternator will charge both.
I'd like to do this on mine. Where could I find more information?
badpeanut is offline   Reply With Quote
Old 01-15-2005, 10:15 AM   #27
Gregsmx
Gregsmx's Avatar
Spencra, the roll bar is standard equipment on these years Blazers. You may be able to find one at the salvage yard, or by posting a wanted ad here on the boards. A lot of people remove the roll bar when lowering their truck, especially 2-wheel drive customs.
I have seen two different versions of the roll bar. One version (like mine) the angle brace mounts to the bed floor, and a second version in which the angle brace is a little higher, more pronounced, and mounts to the wheel well tub.
Badpeanut, there are several sources for dual battery set up information. Since it was a GM installation on the Chalet and on some diesel applications, there is an assembly manual diagram (attached). You can get a battery tray for the drivers side from LMC Truck (Longs Motor Company). And finally, you can get the relay assembly from stereo shops or auto parts. Custom auto stereo shops are used to dealing with lots of batteries and alternators so they should be able to set you up with the remaining pieces parts necessary.
I hope this information is helpful to ya'll.
Greg.
'75 Blazer RAT 4X4 "BLAZIN" - Custom frame off
Here's the website I'm uploading pics to: Greg's frame off project
Gregsmx is offline   Reply With Quote
Old 01-15-2005, 07:59 PM   #28
spencra
This, is my BOOMSTICK!
spencra's Avatar
Thanks a lot Greg.
Larry
Got rid of my projects for now.
1980 Jeep CJ7
1998 Nissan Sentra (my car)
2001 Toyota Sienna (wife's, of course)
spencra is offline   Reply With Quote
Old 01-16-2005, 10:30 AM   #29
MSL
MSL's Avatar
I agree with everyone that is one sweet blazer for sure.
MSL is offline   Reply With Quote
