01-03-2005, 09:40 PM | #26 |
BAD BOW-Silverado XST
I'm going to try and get some of the neighborhood kids to help me push it in the garage tomorrow. If I can get it in, I'll look into finding the problem on Wednesday. It should not take me long to find it with some help. I mostly need someone to help me push it and bump the motor.
01-05-2005, 10:57 PM | #27 |
IT LIVES!!!! Spent $64 and it started on the first crank. I just need to warm her up really good and reset the timing!!! It took me longer go and buy a part than to remove and install it. Next, get the registration and inspection sticker done this week!!
Anyone up for a 100 MPH challenge?? |
01-05-2005, 11:09 PM | #28 |
looks like the 383 is once again on the back burner
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
01-06-2005, 09:34 AM | #29 |
Will that thing ever die!?!? :p
01-06-2005, 09:52 AM | #30 |
Right turn Clyde
What fixed it?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
01-07-2005, 12:33 PM | #31 |
The 383 is not on the back burner too far. I am in the process of locating parts. I just spent a day in SA looking for a short block. The AFR heads will take about 6-8 weeks to get once I order them. I have a overall plan I just need to execute.
The loud pop I heard was not the timing chain. It was the ignition module!!! I never heard of one pop before now. I should have suspected it a while back. At idle under very hot conditions the motor would shut off but start right backup. This time the module failed while running and hot. |
01-07-2005, 01:07 PM | #32 | |
Insert Witty Text Here
Slonaker |
01-07-2005, 07:00 PM | #33 |
I have a roller block. I'm going to use it as a core or trade it on another. I'l be visiting SA again probably within the next two weeks. I found two places that are recommended. If the truck holds up I will probably drive it to SA just for fun.
01-07-2005, 07:23 PM | #34 |
Let me know when you get into town, if you have the time.
Slonaker |
01-07-2005, 07:58 PM | #35 |
you paid $64 for an ignition module?! someone saw you coming!
01-08-2005, 12:40 AM | #36 |
You forgot the rotor, cap.......
