Old 01-26-2005, 03:08 PM   #26
fastbagged68
fastbagged68's Avatar
The Spacers I had on my crossmember where dished on one side and flat on the other. about 1/4" think. I had them on both studs.
fastbagged68 is offline   Reply With Quote
Old 01-26-2005, 03:48 PM   #27
XXL
Señor Member
XXL's Avatar
Originally Posted by fastbagged68
You also need your borgenson joints to clear your upper arm, any time you go that low you are going to need to do it.
Where are the budweisers?
It looks like the problem is the ART upper arm width that's causing the real problem. With the stock uppers on there is a lot more clearance (though I don't know if it's enough).
And I've been on the phone with Borgeson this morning... working on a solution.
XXL is offline   Reply With Quote
Old 01-26-2005, 04:05 PM   #28
fastbagged68
Here is something to give you a baseline for your steering.... It's not the best but it could point you in the right direction... http://www.ifcustom.com/projects/projectpics/k-m/marissa's%20suburban/marrissasubdrop/subdrop36.jpg
Old 01-26-2005, 05:03 PM   #29
lolife99
67-72 parts collector,…
lolife99's Avatar
Is it true that you can use a "VAN" steering box? Like a early to late '70's model? Something about the box being taller, to help clear the upper arm. Seems like "fiveeightchevy" posted. Anyone?
Keith
Convert to disc brakes.
Old 01-26-2005, 05:27 PM   #30
fastbagged68
Bill Dermond (aka roadsurfer) said you can...but you need to fab a few things up to make it work. Need to also make sure it is the right box. ie. doesn't turn the oppsite you turn it. It raises you box up like 3 inchs. i think. And if you want to find Bill Dermond...goodluck!
Old 01-26-2005, 05:27 PM   #31
fastbagged68
Bill Dermond (aka roadsurfer) said you can...but you need to fab a few things up to make it work. Need to also make sure it is the right box. ie. doesn't turn the oppsite you turn it. It raises you box up like 3 inchs. i think. And if you want to find Bill Dermond...goodluck! go to sportruck.com and look for it there. heposted about crossmember drop there over a year ago.
Old 01-26-2005, 08:31 PM   #32
XXL
Señor Member
XXL's Avatar
Good pic. This is what I was thinking. I've been on the phone with Borgeson this afternoon. Ultimately it'll just be a matter of throwing time and money at the problem
Old 01-27-2005, 03:11 AM   #33
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
WOW, you are moving along! That piece looks really familiar...
Originally Posted by XXL
BTW... capt kaos, we discussed potential tie rod clearance issues, but you felt it wouldn't be a problem. Oops
I expected grinding on the lip area, the clearance area I was refereing to that wouldn't be a problem was in between the framerails for the centerlink. Sorry for the confusion.... I appologize.
Originally Posted by phantom dually
OUCH I remember asking those questions to Bill Turner when I was only going to do the member and not the Rack and pinion. He spoke of turning the parts backwards somehow?? Not sure if he was blowing $hit up my ARSE or what??
I am guessing he was talking about flipping the tie rod ends to point up and retapering the spindles to gain clearance at the framerails so they don't have to be notched as much, but... you aren't actually moving the centerlink down, so....
Originally Posted by Slammed67
Did '73+ trucks have such a spacer on them from the factory?? That's the only explanation I could come up with.
This is the way they go. Bevel pointed inside.
The 73-87's have a beveled washer that goes into that "slot", shims are placed between it and the frame.
I have heard that, but I haven't found "the box....
No, It won't be enough...
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 01-27-2005, 11:41 PM   #34
XXL
Señor Member
XXL's Avatar
low?
Old 01-27-2005, 11:44 PM   #35
XXL
Señor Member
XXL's Avatar
Parts to do this kind of linkage are on the way. Borgeson ain't cheap
Old 01-28-2005, 12:11 AM   #36
Captkaos
Captkaos's Avatar
low?
SWEET!!!!!
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-28-2005, 12:58 AM   #37
Shev
Head Peon
Shev's Avatar
Took a little digging but here is Bill Dermonds (aka Roadsurfer) post from Sportruck on the van steering box mod. I've got pics of his stuff somewhere on my puter from when I had my burb site up and running (hopefully it'll get back up soon) I'll dig them up if somebody wants to see them...
Link to post
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4
Shev is offline   Reply With Quote
Old 01-28-2005, 12:58 AM   #38
SCOTI
SCOTI's Avatar
Well, I tried to re-post the pic that had the u-joint linkage between the column & steering box but for some reason it won't let me open the attachments.
Are you doing the 3-universals + 2 intermediate shafts like the previous pic or what? I'm not sure how I feel about that set-up from a strictly visual aspect.
Am I alone in my observations?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-28-2005, 01:06 AM   #39
Shane
Shane's Avatar
Lookin' good ....
It appears that I am gonna have to pack up and move West in order to get my "bucket of bolts" completed.
Good work fellas ... yer makin' me proud!
P.S. Kenneth ... please clean those wheels.
Shane is offline   Reply With Quote
Old 01-28-2005, 01:26 AM   #40
Captkaos
Captkaos's Avatar
I wondered what happened to your Burb site....
You know us, we like pics! I would like to see what ya got if it isn't a problem.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-28-2005, 01:35 AM   #41
Captkaos
Captkaos's Avatar
No, your not alone, BUT you need 3 to get it up over the upper control arm.
Here is another twist of the same. This is SmashingChucks truck:
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-28-2005, 01:43 AM   #42
SCOTI
SCOTI's Avatar
I've put effort into cleaning up the visuals under my hood. I want to camouflage whats there or make it smooth. That set-up doesn't look like it would work w/my theme.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-28-2005, 09:30 AM   #43
smokekiki
Mike
smokekiki's Avatar
I think if You paint the shaft to match the frame and or steering box,it won't stick out as much.I don't mind the look.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 01-28-2005, 03:46 PM   #44
XXL
Señor Member
XXL's Avatar
It took a LOONNNNGGG time to get them to look that way in the first place. If I cleaned them, I'd have to start all over. It's all about the look
SCOTI I've put effort into cleaning up the visuals under my hood. I want to camouflage whats there or make it smooth. That set-up doesn't look like it would work w/my theme.
Ditto, but I've got to do it... or plan my trips very carefully so as to avoid all turns. So... I'm contemplating a formed "shield" to fit over it once it's all in place. Stay tuned.
Old 01-28-2005, 09:24 PM   #45
SCOTI
SCOTI's Avatar
We discussed options w/the inner fender. Possibly trying to use some of it to hide stuff but won't know until I put more stuff together.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-01-2005, 10:05 AM   #46
XXL
Señor Member
XXL's Avatar
Time to move the exhaust...
Old 02-01-2005, 11:46 AM   #47
Captkaos
Captkaos's Avatar
Lookin' good. Got an ETA on the Borgensen joints yet?
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 02-01-2005, 12:09 PM   #48
XXL
Señor Member
XXL's Avatar
They are "en route." I should have specified overnight shipping
On a side note, for a preview of a future rant... I spent some time on the phone this morning with Jason at Air Ride Technologies. For all of you who've seen me give ART props for their customer service for the last 5+ years, blehhhhh. Apparently they sold all their customer service and now they're relying on their devilishly low prices... or not. I've bought from them exclusively (save the bags I recently got from Captkaos), and paid their high prices, all because I bought into what was a very strong customer service experience. Today, in one single phone call, that has been wiped out. Congratulations to Jason at ART for your accomplishment.
Old 02-01-2005, 02:04 PM   #49
fastbagged68
ART is over priced! They make nice stuff but not worth the money.... A little trick...instead of buying there upper arms- flip your over and flip the ball joints and flip sides.....This corrects ball joint angle. To get creative cut out the center and weld in what you want!
Old 02-03-2005, 02:25 PM   #50
Slammed67
Progress = 0%
Slammed67's Avatar
Ok, I e-mailed XXL progress pics from last night but apparently he is actually busy working for a change today so I'll post them
I installed the Borgeson joints/Double-D shafts last night along with a bracket that I fabbed up. I still need to finish welding the bracket pieces together (there are just tacked now). The steering shaft now clears the upper a-arm, even when the front end is lowered all the way. I used 1/2" copper piping to mock up the double-D shafts before cutting the actual shafts to length to prevent waste/incorrect lengths.
All I have left to do is bleed the brakes and install the new front shocks (I'm waiting on some lower shock studs from ART).
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
