Old 02-05-2005, 12:06 AM   #26
Rod
Next time I come across a H110 I'll take pics...there easy to tell the difference..they have 10 bolt hubs..not 8.
The cover is domed but has a section to take in account the larger gear set. They are in the 1 ton style chassis..2 are around here.
Your talking 6.13 or is it 6.17 gear ratio though in those units.
Those trucks use a different braking system also.
The ho52 -ho72 could have detroit locker in them...all my own 3/4 up use that style diff and all have detroit lockers in them.. I have a dana 60 rear too as a spare with its posi too if need be.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 02-05-2005, 08:29 PM   #27
72_Chev_Truck
My truck came with 3.73's in it, at least when I got it, and I swapped the gears out of another coil sprung truck (1970 model i think) to get the 4.10 gears in my current truck. im gonna have to look at the axle when i get home, its currently sittin in the garage waiting for an exhaust and wiring an hour away from me. wish i had a garage up here to work in.
72_Chev_Truck is offline   Reply With Quote
Old 08-02-2009, 01:23 PM   #28
capev86
Re: What axle do I have?
how hard would it be to convert an ho52 to roller bearings. i plan to flush the rear axle on my 72 burb and run royal purple, but if there are any easy ways to upgrade while i have it apart to change the 4.57 to a 4.10 (or perhaps the rare aftermarket 3.90) i'd be all for it.
capev86 is offline   Reply With Quote
Old 08-02-2009, 04:54 PM   #29
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
a gear swap on an HO rear is very simple. Just remove the 3rd member drop out (like a for 9 inch) and replace with one from another HO rear. Any 3/4 ton with a small block and an automatic should have the 4.10, I've personally never had much problem finding them.
wow... this thread is over 4 years old.
Old 12-15-2009, 11:15 PM   #30
David Wymore
Bringing this back up...
My buddy just got a '65 C20 with an HO in it. He wants highway gears, what is the best option? I think I understand these trucks came with this link/coil suspension with Dana 60s at some point, so I think that would be a good
option if we could find one. What's the tallest gear ratio available for a 60?
Or a 14bolt? Our other thought was to put the suspension bracketry from the H0 on a 14 bolt. Can the guts (R&P) from a 14 bolt be used in an HO? I have about 3 around, maybe we could put one good one together. Then there's still lack of parts availability in the future...
David Wymore is offline   Reply With Quote
Old 12-15-2009, 11:40 PM   #31
2tons of fun
no the gears can not be swaped from a 14 to the ho. you can swap the side gears and axle shafts though.
i dont know about the fastest gear for the ho but you can get a 3.23 for a 14bff and a 3.08 if you get a d61/d71[dodge diesel axles]
2tons of fun is offline   Reply With Quote
Old 12-16-2009, 12:46 AM   #32
Longhorn Man
An 8 lug Dana 60 was avalible with a 3.54 in big block C/20 trucks and burbs from 68 - 72
Old 12-16-2009, 11:19 AM   #33
David Wymore
Anyone have any idea what the largest tire that can be stuffed under the rear is? 3.54s with 33s would work.
Old 12-17-2009, 12:38 AM   #34
2tons of fun
32x11 afaik
Old 12-17-2009, 12:43 AM   #35
David Wymore
I think we're gonna put a 12 bolt I have with 2.76s in it with the coil/arm style susp brackets welded on it and get some 6 to 8 wheel adapters.
