02-09-2005, 05:27 PM | #26 |
BINGO!
Same old gearbox. Same old hose. Same old fitting, check valve or whatever. Newer pump. Worked like a champ for me. Like I said before, these are just a few things that I wish I would've known when I started the serp. project. It would've saved some trips to the junkyard. Later, Brad p.s. If anyone knows anything about trannys (I don't), please check the "engine & drivetrain" board. I've got a prob with a TH-350 I need solved ASAP.
Why do we drive on a parkway and park on a driveway? |
02-09-2005, 09:32 PM | #27 |
Z28 Steering Box
Sachmo - I don't think you can use the Z28 box on the truck. Trucks mount on the outside of the frame and Camaro/Firebird mount on the inside. The bolts are on the wrong side of the casting I believe. If somebody knows differently let me know as I would like a quicker box.
Thanks - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
02-09-2005, 11:09 PM | #28 | |
02-10-2005, 10:24 PM | #29 |
68cst_ss490
Putter. I found a part number for that bracket with idler. but being the idiot I am I left it at work. By chance a early 90's s truck came in today with that
idler bracket on it. I hope to remember the number for you tomorrow
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
02-11-2005, 12:04 AM | #30 |
If you have both styles of power steering hose, you can change either end by cutting the metal end in a straight section and put the two together with a steel (not brass) compression fitting, or union. The steel fittings are rated for high pressure, the brass ones are made for copper tubing. You can also run an A/C compressor without it being functional as only the pulley turns until the clutch is engaged. Frank
02-12-2005, 03:04 PM | #31 |
68cst_ss490
hey I got the part number for that a/c idler bracket
Its a GM numebr.....10118713 hope that helps you out Dean
02-13-2005, 11:35 AM | #32 | |
that is a kewl setup. I need the info on the guy that fabs the gas tanks, if you still have it. PM me the number. Thanks
2004 Corvette Coupe Black LS1 (daily driver) 1973 Ford Bronco (resto/mod @ 95%) 1991 GMC sportside Pickup Truck, 468c.i.d. ('nuff said) 1997 Ford F150 4.2L 500k+ miles (trash hauler) 2011 Nissan Juke (wife's daily driver) 1943 Ford GPW WWII jeep (waiting its' turn) |
