03-09-2005, 03:33 PM | #26 |
Kit
Alex;
The only items they didn't mention in the kit are axel bearings & axel seals. I recomend replacing them also if your going this far. It won't add much to the over all cost. The reason you should replace them is the same gear lube that lubricates the gears, lubes the axel bearings. So any metal fragments that were in the lube get into all the bearings. $900 sounds like a much beter deal, as long as the guy knows his stuff. Gary |
03-09-2005, 03:51 PM | #27 |
Thanks Gary!!! I will do the axel bearings and seals as well...you are right!!! This guy that I found knows his stuff for sure!!! Parts should be here by Monday and to the shop on Tuesday. Sad thing is when it's all fixed, I think I might have to sell it. Oh well it's just another hurdle or bump in the road of life.
Alex 1971 Lil' Red 350 SBC 700R4 |
03-09-2005, 08:50 PM | #28 |
That's stinks that you may have to sell it. I hope you find a way to hang onto it. Those 2 trucks of yours would be an awesome pair.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
03-09-2005, 09:10 PM | #29 |
how did this rear end failure happen???
1985 Chevrolet C-30 454 1-TON Dooley 1969 CHEVROLET CST-10 PICK-UP Good memories 1999 Chevrolet Z71 Ext. cab 5.7L Good Memories With a quart of oil, and a gallon of gas, she won't let no other car pass!!!. & FOREVER |
03-09-2005, 11:11 PM | #30 |
I had 3.73 posi's for sale in a number of posts, could have helped you out. Maybe next time.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
03-09-2005, 11:24 PM | #31 | |
F.A.S.T. president
Should you spend the extra $ on a posi......only if your planing a lot more power or some more then casual off roading.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" |
