Old 12-27-2013, 01:01 PM   #26
burnin oil
Re: low low oil pressure after warm HELP
Originally Posted by GASoline71 View Post
Almost a 9 year old thread... Draggin' the waters...
It will never read 30-40 psi at idle when warm. That's race car pressure right there.
Gary
My 400sb runs a little warm on the interstate and gets around 20psi after I get off the big road. Normal driving and well up to temp nets me those 30-40 psi at idle. My idle is a little higher though around 900 in neutral Might be time for an oil cooler as my filter is a little closer to the headers than I like making me run the short filter.
burnin oil is offline   Reply With Quote
Old 12-27-2013, 02:04 PM   #27
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Wow... All your oil must be up in the valve covers trying to drain back down. Must be a high volume/high pressure pump.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 12-27-2013, 08:52 PM   #28
Crosshair Cowboy
Crosshair Cowboy's Avatar
Well, I changed the oil filter from the Fram to a Wix. I didn't figure that it would make a difference in oil pressure, and it didn't.
Meeting with the engine rebuilder this weekend. I'm pretty sure I'm looking at pressure getting past the mains.
Engine was rebuilt, new cam, polished the crank. In hindsight, with the money that I've got sank into this motor, I would recommend just getting a crate motor.
I definitely want to find out what's going on before I put the front clip back on, and final paint.
1969 K20 4x4
1989 V1500 Burb
Crosshair Cowboy is offline   Reply With Quote
