#26 |
If I remember right on the size you need to drill a 1/8th" hole just above the lower hinge for the window guide channel. You might be better off removing the fender's they are easier to rehang than the doors. And you can access the spot you need to drill the hole. If you have really nice vent windows start getting use to the idea of cutting them up. or try and find a junk set all you need is the track. Did you get clear or medium tint ?
If you have any problems shoot me A PM. Later, Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#27 |
oh crap i sold the wing windows!!!!!
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door Last edited by special70gmc; 04-05-2005 at 06:17 PM. |
#28 |
Oh, that should be the easy part to correct with the install process. I wrecked 2 set's the first set i pulled the chrome strip off of it then when I installed it I saw a bear steel edge..
![]() ![]() Sent you a PM
