#26 |
![]() Join Date: Jul 2015
Re: Front sway bar....WOW!
Anyone know the interchange on a leaf spring 3/4 ton rear sway bar? I know the later model rigs will interchange, and even the same model year and capacity 3/4 ton Fords.
I am doing it. |
#27 | |
Have a look at the first pic in this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=768849 This particular type of sway bar can't go too high though. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#28 |
I have the CPP rear bar on my 72 long bed. I added both front and rear bars and they made a huge difference together. I went from nearly scraping the door handles in turns, to riding like its on rails. It stays super flat now and off ramps are a lot of fun hahaha. The CPP rear bar fits fine on either stock height or lowered trucks. On a lowered truck you may need to shorten the end link bolt and sleeve, but mine didn't need it with the ECE 4/6 drop. I highly recommend, you won't be disappointed.
72 C10 lwb fleetside -stock 350/350 combo |
#29 |
Yep, I agree... all the difference in the world with a beefy sway bar. The truck will even track better on the highway.
POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
#30 | |
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
#31 |
Who Changed This?
![]() Join Date: Jan 2013
I have the factory sway bar on my truck. It was fine when I had the Michelins on it, but with the Firestone Transforce tires I experience some over steer, even with 10 PSI more in the rear tires. I'm thinking about a rear stabilizer bar to help with that, especially since I put a new shell on with a higher center of gravity (it's over a foot higher), and don't have much weight lower down, since I scraped out all the junk in the bed. Any recommendations?
It's a Dana 60 with leaf springs, in the back.
#32 |
Waiting for my anti sway bar and a set of overload springs too!
Not seeing any raise on the horizon to accommodate these purchases. Bill
#33 | |
Here is a pic or two, it brings the rear up in stance about 1/2 to 1 inch when mine is empty. Good Products from that company for sure. I just got a email from them and their sway bar will mount with no modifications other than drilling a couple of holes in the frame. |
#34 | |
Who Changed This?
#35 |
Post Whore
![]() Join Date: Aug 2014
man when I installed one on my '74 I couldn't tell the difference, it's like gliding a space shuttle, ha ha
#36 |
I just installed a 1-1/4" front stabilizer bar from an 1986 C30 onto my 1971 C20. I was surprised that it wasn't a direct bolt on. Based on all of the feedback here, it was supposed to fit?
Well, from a guy that has actually done it, I can say it sorta fits. The frame straps bolt right up, but the straps on the control arms will need relocated. The square body bar is actually wider by maybe four inches. The straps have to be moved outward to where the bushings almost interfere with the bump stop support. At this location the end of the sway bar is not quite long enough to completely pass through the bushing. It is short by about 3/16", although it is still with the metal strap. Seems to work okay. So, there you go, the truth about "will-fit". Want more? How about I help you out with some part numbers? 1.25" sway bar straps = (4X) GM 88891781 (still available from GM) 1.25" sway bar bushings = (4X) Elgin 5K6476 (same as Moog, but are black instead of blue. These are all made at the same USA mfr, and are a thermoplastic instead of urethane). Hopefully this will save someone an unwanted surprise.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs |
#37 |
I have the 1 1/4 bar from a square body and it was a direct bolt-on. I wonder if you got a different bar.
#38 |
guess I was just lucky on both of my longhorns
I started out with nothing - and I still have most of it |
#39 |
Now you have me wondering. I never saw the truck. Paperwork lists 1986 C30. Maybe the guy who pulled it misunderstood and took it from a 1996?
#40 |
![]() Join Date: Feb 2009
I wonder what their rationality was for adding one. Wouldn't surprise me they were installed on everything short a Custom. From here I don't know what years.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 06-05-2020 at 09:48 AM. |
#41 |
My 67 C20 had the front sway bar, otherwise bone stock...maybe all 3/4 tons and CSTs got them?
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
#42 |
You got me, all I can say is my 71 C10 SWB Custom Deluxe & 72 C20 Super have one.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#43 |
My '71 C20 came stock with an 1-1/16" front bar.
Still baffled about which vehicle my 1-1/4" came from. It's not later than a square body as those went to end-links at the control arms. It is from a GM since it did include two straps and those were clearly GM straps. An odd thing about the bar is a drop center between the frame straps. Must have been added for clearance on whatever vehicle it came from. Do the vans have different control arms? Maybe it was a G30? Could it be from something even bigger like a C50?
#44 |
maybe because of the z81 option? they're both special campers but only the ochre one is a cst..
#45 |
![]() ![]() Join Date: Sep 2008
Only the guy that ordered the truck knows the rational behind checking that option box.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
#46 |
It was an option, decided upon by the person that ordered any truck.
#47 |
The front sway bar on my 71 Longhorn came off a 76 C2500. Direct bolt on.
#48 |
One of those things you have to ask yourself, WHAT WAS GM'S THINKING? The stabilizer bar and the full foam seat should have been standard equipment since day one. Probably a big reason why Ford started to surpass Chevy in sales in the 70's.
#49 |
I am just about finished with my front Power Disc conversion so I am now almost ready to install the Anti-Sway bar.
#50 | |
![]() Join Date: Aug 2004
http://67-72chevytrucks.com/vboard/s...d.php?t=800524
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
