#26 |
I feel the need to make some comments...say what you will to me, but moving the bag up on the trailing arm does not allow you to run less pressure. In fact you will have to run more pressure because the effective spring rate at the axle is decreased as you move the bag up the arm. Effective spring rate (Reff) is calculated as such: Reff = SP x (L1/L2)²; where SP = your spring rate at the bag, L1 = the distance from the trailing arm pivot to the bag (spring), and L2 = the distance from the pivot to the axle centerline. So...Spring Rate has to increase as you move the bag closer to the pivot.
Why not use air-bag over shocks like the shockwaves and mount them directly off of the back of the trailing arms? This would allow you to run low spring rates and actually give you a slight mechanical advantage over the axle.
'68 Chevy Stepside in Frame-up Restoration process. 292 CID Clifford Performance Modified T56 6-speed Tranny Slammed, Custom IFS and IRS Money?...Too Much! |
#27 | |
Progress = 0%
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
#28 | |
#29 |
Yeah, this is just my play toy. I could careless if it rides like ****...... as long as look good
66 C10 (under construction) 1.5" crossmember drop 2" Z'ed frame 8" rear notch Watts-link Bagged DJM 3" spindles Last edited by DM310; 05-11-2005 at 05:10 PM. |
#30 |
Cantlever suspensions ride very nice better than over the axle, Also running big wheels, lift is needed, True it adds more stress to the arms but if you brace it correctly there is no problem. Shock waves are nice but i heard that they get less lift than firestones(about 7). Its really up to the person and what they are looking for. Air over coil suspension is 100 percent better. Theres so many different variations of rear systems and what you're looking to do. When I did mine i wanted both a nice ride and lift. I have a longbed and in pennsylvania the roads SUCK. Getting extra lift in the back is good for me and my roll pan, plus its a coolness factor to take the plate from sitting on the ground to almost 26in in the air. As for bags Im running Slam specialties. I like them, little more but well worth it. Well thats my two cents, And my opinion...So its really up to the owner.
#31 | |
Mike
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
#32 |
I'm glad i'm not the only one. Even pulling in and out of some places
#33 |
Just Don't Stop!
![]() Join Date: Feb 2004
You just reminded me how much I love Texas...
1968 C10 build in process TT LSA/6L90e/9" |
#34 | |
Ummm Ok
#35 |
Tell me how the hell what I am building is dangerous. I have posted many pics along the build process and no one has said anything about it not being safe. I am not just some jackass w/ a welder here. I was being a smart ass when I made that commit. What have you built?
66 C10 (under construction) 1.5" crossmember drop 2" Z'ed frame 8" rear notch Watts-link Bagged DJM 3" spindles |
#36 | |
#37 |
Nothing clever
some people consider this art!
![]() I know I can't "paint" and "sculpt" like any of these guys!
Got "the Midas Touch!" Last edited by cojnit; 05-16-2005 at 11:40 PM. |
#38 |
Re: Rear airbag mount on trailing arms (not stock location)
Bump on old thread!!
I'm figuring on taking the springs off and lowering it as far so that the axle(no current c notch) hits the frame Then I'm going to slide the bags with mounts attached and compressed to the furthest location forward they will fit.. Concept is that with minimal psi it should bring the truck up to an Ok ride height and have a little travel either way Gussets are good things to have in an off the frame/arm mount In fact u can also add 1 each side as if a roof over the bag welded to the edge of the top n bottom of the frame and/or arms |
#39 |
And I'm going to run ss7s in the front with hopefully cupped arms
Ss8 in the rear up from the coil spring spot I have a stepside so I'll put a mild c notch in it eventually Maybe dual 3gal tanks under the cab or where ever outside of the bed I can fit them York on board Hard line copper n Manual ball valves under the radio |
#40 |
![]() Join Date: Jan 2011
It will set on the frame rails with a bag in the stock location. I will actually set up into a 2" notch and rest on the bed floor with the bags in the stock location. Every inch you move it forward will increase the amount of air needed as you loose mechanical advantage.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#41 | |
#42 |
maybe put the 8s in the front
