05-04-2005, 04:54 AM | #26 | ||||
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. Last edited by 4x4Poet; 05-04-2005 at 05:01 AM. |
05-04-2005, 06:37 AM | #27 |
Livin' it up.
Okay fellas, main reason for OEMs typically not using higher grade fluid is cost and the fact that most vehicles DO NOT require any sort of higher end fluid.
As stated Dot 3&4 are hydroscopic and absorb moisture (depends on how good the seals are all over) very slowly. Moisture in the brake lines does significantly lower boiling point on vehicles but as stated those conditions are typically not apparent for an average hot rodder or even most road racers. The BIG problem for vehicles is substantial sustained braking. If you've got your truck loaded up to the gills at or over GVWR and you decide to go down a MONSTER (ie from Towne's Pass to Stovepipe wells in Death Valley, CA) hill you have quite the ability to heat up those brakes and the fluid... If you get it hot enough you boil the fluid in the caliper and you're in BIG trouble That being said the rate of absorbtion of moisture in systems is usually VERY slow (i'm totally unsure on these old trucks of ours). As far as how well our trucks perform under 'extreme' braking, your guess is as good as mine, many tests and procedures now in place with the auto industries did not exist back when these trucks were created. Back to the original ?... running silicone fluid into a completely dry system. This should be perfectly fine IF (and you have no way of knowing exactly unless you contact them and can drudge out an anser) the seal manufacturers tested their parts to be able to withstand silicone fluid. If the seals cannot handle the fluid it will degrade them, causing leaks and possible failure over time. If it were me i'd say go for it and odds are VERY good that it'll all be fine and dandy, just do system bleeds every year or so for top performance to help keep moisture out. Hope you guys take my words as opinion/advice but i do know HARSH testing procedures for brakes and many of the standards the industry has to live by and with you guys can guess why
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. |
