Old 05-06-2005, 09:23 PM   #26
screamin_c102
screamin_c102's Avatar
Originally Posted by MARIOS68PANEL
Where can I get spindles that work with drums? That is the way I should go.
$700 or so from cpp, their kit is a drop spindle/disk conversion.
$260 from ECE (Carolina classic) but requires a disk conversion.
Check this out Mario... http://www.sporttruckdirect.com/spindles.html#C10spins
Chevy C10 / GMC C15 2.5" Drop Spindles:
Whether your C10 or C15 truck came with disc brakes or is
an early model that has been converted to discs, we have a
Western spindle for you that will bolt up perfectly to your
existing ball joints and tie rod ends without modification.
And because they're 2.5" spindles, they won't cause the
wheel clearance problems that some 3" spindles cause.
60-70: 219.95; 71-'72: 219.95; 73-87: 219.95 / pair
screamin_c102 is offline   Reply With Quote
Old 05-06-2005, 09:26 PM   #27
MARIOS68PANEL
Active Member
MARIOS68PANEL's Avatar
I get the ece but who is cpp? thanks
67 short step
71 Custom
MARIOS68PANEL is offline   Reply With Quote
Old 05-06-2005, 09:28 PM   #28
screamin_c102
Classic Performance Products
http://www.classicperform.com/6092chevtrk.htm
Old 05-06-2005, 09:29 PM   #29
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 05-06-2005, 09:29 PM   #30
68w/sbc406
68w/sbc406's Avatar
you beat me!!!
Old 05-06-2005, 09:31 PM   #31
screamin_c102
Originally Posted by 68w/sbc406
you beat me!!!
wireless DSL baby!!!
Old 05-06-2005, 09:33 PM   #32
68w/sbc406
68w/sbc406's Avatar
i got comcast. it just took me a while to find the damn site
Old 05-06-2005, 09:34 PM   #33
screamin_c102
Old 05-06-2005, 09:40 PM   #34
MARIOS68PANEL
Active Member
Everything I see has to have disk convertion. I cant go that much. I dont see any spindels that I can use my drums on. Unless Im blind .lol
67 short step
71 Custom
Old 05-06-2005, 09:53 PM   #35
screamin_c102
Nope, I'm goin' blind, I didn't even see the "early model converted to disks" part of the description!!!
I need to get more sleep
Old 05-06-2005, 10:01 PM   #36
68w/sbc406
68w/sbc406's Avatar
and on the cpp it says oem spindles 2.5 inch drop, but when you click on info it says they are for converting to disc. there has to be something out there
Old 05-06-2005, 10:10 PM   #37
MARIOS68PANEL
Active Member
I been told they dont make them . That is why I was so surprised to here they had them. It would be the least expensive way to go if someone makes them.
67 short step
71 Custom
Old 05-06-2005, 10:32 PM   #38
68C15
blood type; Retumbo
68C15's Avatar
in that case I would recommend some 2" springs. everything else will start a snowball effect. (cost continues to escalade until you are broke & single)
or you could spend some time in the bone yards hunting & gathering parts to do a disc swap from a later model.(73-87)
on mine I have '80 spindles & ball joints & steering with the original '68 Xmember.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 05-06-2005, 11:10 PM   #39
68w/sbc406
68w/sbc406's Avatar
i have like 750 into the parts i have to do my JY disc swap (thats counting the lower control arms and every tie rod and ball joint) i made my own bag brackets i just need to buy the bags and cap them off
