05-06-2005, 11:30 AM | #26 |
2 more cents worth; hey what would you folks think if I told you we owned a SBC that turned 10,000 RPMs with standard 1957 type pulleys and a commercial grade Gates v-belt !!! No, my eyes aren't brown this Modified stock car won a championship at a local track it even won 3 races a night for eight straight weeks. Ok enough of the soap box; about 10 or 15 years ago Hot Rod magazine and a few others did stories on serp. belt systems and said that you gain between 3-15 horse power. Some of you may have the articles in a stack of old magazines. I personally am running v-belts for now, but you know they do have deep groove pulleys for high RPM !!!
05-06-2005, 11:31 AM | #27 |
Excelsior, You Fathead.
I'm too cheap to switch over and I don't race. My truck was my grandfathers, he beat it to death with over 200,000 hard miles and never broke a belt.
Go Navy. The Sea Is Ours. Budget 350 Build http://67-72chevytrucks.com/vboard/s...38#post2264638 |
05-06-2005, 05:48 PM | #28 |
68cst_ss490
heres the serp set up i had on my small block its off of a 91 gmc 1500. it even has an a/c delete idler bracket for those with no a/c. a serp setup is the only way to go...reliability...quieter then v belts and they alos are easier to maintian and change belts
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
05-06-2005, 07:16 PM | #29 | |
got boost?
as for true race cars;#1:1000 race miles are equivilent to 10000 or more street miles. #2would you consider a 10 second sedan a true race car? i do!& so do the one's being spanked by it at the track.it is of little concern that it runs those times with bfg ta radials, drives to the track at ennis & home to corpus christi & is tagged & inspected. whats run at the track usualy is what is run on the street.just a few years later.it's called r&d. most manufacturers subscribe to this using factory teams to learn how to make their stuff better, stronger & sometimes faster. the benefit of v-belts; 1: they are cheap 2:they work. 3:unless you lose the water pump or crankshaft, when one accessory fails, the others continue to operate.it's called redundancy. 4:a v-belt setup is lighter. 5:tensioner?i don't need no stinkin' tensioner! 6:less moving parts.
'70 chevy lwb w/'67 hood. 357 s.b.c. built, 4l60 w/vigilante lockup high stall converter, edelbrock pro-flo,brodix heads,comp cams rollerized w/ belt drive, one piece d-shaft, yada, yada, yada..... '82 honda v45 sabre"the black" |
05-06-2005, 07:31 PM | #30 |
Cowboy Fan for Life!!!!!!
Has anybody got pics and would put together a how-to on this setup, what you would need and what to look out for? Or has it aleady been done and you have a link? Thanks,......Jerry
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
05-06-2005, 10:17 PM | #31 |
'Burban Legend
Black is Beautiful
Purs,
That is EXACTLY what I am looking for. I will have to research that a little to see what I can find. Just curious, was the PS not part of the late model SERP system? PM me with any info you could supply, if you would be so kind. Thanks, Hot Rod |
05-06-2005, 10:44 PM | #32 |
Got Big Block?
it was all off the 86 1 ton, the PS pump, brackets, all of it.
"Experience is what you get when you didn't get what you wanted." |
05-07-2005, 09:26 AM | #33 |
72GMC51
Mine is a GM Performance parts setup it comes with all of the brackets, belt, water pump, alt, power steering pump and either a pulley or an air compressor, instruction etc. works great and I thought for what you got was a good price.
JC
72 GMC 2wd 1/2 long 350 700r4 A/C PS PB 4:10. Are they ever really finished |
05-07-2005, 01:17 PM | #34 |
i like simplicity....the serpentine takes up the whole front of the motor....plus with running two vs one breaks the other one takes over....a serp breaks and your screwed...
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
05-07-2005, 01:22 PM | #35 | |
F.A.S.T. president
Where do you gen-x guys come up with this stuff? There is nothing wrong with a v-belt as long as you have some kind of mechanical ability and line things up right. Don’t get me wrong, a like and prefer a serpentine because its cleaner. But what you sate is just untrue. The reason they went to serpentine is easy assembly at the factory, takes less space, and self adjusting not that they were coming apart at high rpms.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" Last edited by jamis; 05-07-2005 at 08:33 PM. Reason: speellink |
05-08-2005, 03:13 AM | #36 |
Bite me, import boy
I can't recall seeing anyone on the short tracks in my area running serpentine belts on their cars (in any class). My limited sportsman car would reach about 8100 rpm at the end of the straight and would normally run above 5K all race long. I never had a belt failure in the 2 years that it was run. If I remember right, we had changed them in the off season for normal maintenance. The setup was pulled off of some 70's car in the wrecking yard and bolted on to my engine with new accessories. The last WC race I was at, I don't remember seeing anyone running anything but v- belts either.
I think one of the reasons for the OEM to switch to serpentine belts with a tensioner is for the maintenance free aspect. How many new cars that have no grease points, as they are "lubed for life"? It is an attempt at taking normal prev. maintenance out of the consumers hands. I even heard rumors a few years ago that the automotive industry was lobbying to prevent the hood from being opened by anyone but a factory service tech. The only access was to check oil and water. Serpentine belts have started to show up in the HD trucking industry. I can tell you from first hand experience that those new engines with serp belts have more problems with throwing belts than the old v- belt engines with 1-2 million miles. Not to mention constantly changing tensioner assemblies and idler pulleys, bearings. With that being said, I think that the serp systems have a really clean look to them and if properly set up can give many miles of trouble free service.
Jason '71 C-10 Deluxe-under construction '69 C20, 396,T400-donor truck, '65 C10 project "Facts are meaningless, You can use facts to prove anything that's even remotely true." |
