Old 06-01-2005, 08:21 PM   #26
Super Duck
Chevy Nuttttt
Super Duck's Avatar
I have an extra hei i will send you if you need it. $20 plus ride.
67' Chev swb step side
69' SS elky
03' Chev ext cab 4X4
hey who lernt me to spell
is there anything else?
Super Duck is offline   Reply With Quote
Old 06-01-2005, 08:23 PM   #27
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
They have a tool called a vacuum tester gauge. You just pull the trigger back like a caulking gun and it does the sucking for you. It even has a hand dandy little gauge on there to let you see if your loosing pressure when you shouldn't be.
WRMZ71 is offline   Reply With Quote
Old 06-01-2005, 08:28 PM   #28
krue
Designated A-hole!
krue's Avatar
Yeah, the Mity-vac. It's worth it's weight in gold. Good for checking vacuum, pulling a vacuum, bleeding brakes, etc.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-01-2005, 09:47 PM   #29
djracer
djracer's Avatar
sounds like a bad pickup to me!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 06-01-2005, 10:04 PM   #30
R@nger
Psalm 23
R@nger's Avatar
Well I'm buying ducks distributor off him, but while I'm waiting for that I'll change the pickup...if that doesn't work then I have a different distibutor on the way so I can rule out anything being wrong with the distributor.
Thanks again duck.
71 GMC Fleetside C15(cab), 3/4 ton, 350, Holley Street Avenger 570cfm carb, TH350 trans, Leaf-springs, 2WD.
"Peter are you sleeping on the job? No I have a bug in my eye and I'm trying to suffocate him." - Family Guy
R@nger is offline   Reply With Quote
Old 06-01-2005, 10:05 PM   #31
GlennBrittain
Have you tried running a temorary hot wire directly from the positive battery post to the positive distr. connection. I had some extra wire ends, that made it easy to plug my jumper in on the distr. and used a clip type connector for the battery end.
Battery and amperage are two entirely different components of electricity. I also had adequate voltage going to my coil, but not enough amp's. I also went through all the same steps you have before I ran the jumper. I should have tested my amperage to begin with but it has been to long ago that I took basic electricity and electronics and also a long time time since I have used it.
GlennBrittain is offline   Reply With Quote
Old 06-01-2005, 10:19 PM   #32
R@nger
Psalm 23
R@nger's Avatar
I guess I could try that..it just seems so weird that it worked for so long before and JUST work a couple days ago and then in a matter of hours it didn't work and still won't.
Old 06-14-2005, 11:12 PM   #33
GlennBrittain
I repaired the white wire to my dizzy, truck ran fine, that was at the end of May. Today I found it melted again, this time I ran the 12 g wire directly from a ignition post on the fuse block to the dizzy with a inline fuse. Fired right up, should have ran the new wire the first time.
