Old 06-20-2005, 09:11 AM   #26
Lemield
Lemield's Avatar
Originally Posted by 68haywagon
Lemield I got the radio finally hooked up. I bought 2 cheap 6x9's and boxes from wal-mart yesterday. I got the EQ and everything hooked up and its sounds great for the setup. I mounted the EQ under the heater controls using the screw from the controls. Where did you have it mounted in your setup?
Mike,
The PO had it mounted under the steering column....right in the perfect spot to slam your knee into it if you got into the truck too fast!
Glad everything is working.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
