Junk Chevy C20 Big Block
A4L80 e But its computerised like the 60 is .Is there a way to get around that?
~Rest In Peace~
i'll be glad if i get 6 miles to the gallon
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
Shoot I think it sounds good . Dont you all?
A 350 with a 2bbl carb, 4 speed granny, spicer aux. trans, 4:10 rear, 33" tires.
![]() When me and my dad drove the truck 80 miles to Seguin, Texas we got about 10.5MPG. Right now my Dad's been driving it back and forth to work 70 miles a day(because the 700r4 in his 85 Burb took a crap, that's a whole nother story), and it's been getting almost 13MPG! That's cool with me, but I want my truck back! ![]()
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck Last edited by Robert1970C20rstbukt; 06-16-2005 at 04:38 PM. |
Yea! I love a hard pullin big block when it pins you back in the seat and all you see is the sky. its time to hit the brakes and get in line for another pass .
#6 | |
Just Don't Stop!
![]() Join Date: Feb 2004
On a recent trip to Austin and back, I got 19.7 mpg on the highway and I prolly make 100 horse more than that 402 makes... SPECS: 364 CID, FI gen III small block T56 trans 4.10 gears 29" tall drag radials
1968 C10 build in process TT LSA/6L90e/9" |
#7 | |
#8 | |
Just Don't Stop!
My 307 with a 3pd and 2bb carb gets 17, might be able to add one more if I didnt try to pass so many people
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
you can try one of these... they sound like an infomercial though... bla bla bla save gas bla bla 20% increase bla bla bla helps you get girls bla bla bla
http://www.savefuel.ca/hydrogen.htm
![]() ![]() Join Date: Jan 2005
I would think that a manual transmission with a 3.07 gear ratio is going to be the best combination for good gas mileage. Automatic transmissions are not as efficient as manual transmissions. I had a 6 cylinder 250 with a three speed manual transmission and a .79 overdrive unit that got 21 mpg on the highway. I can get 16 mpg with my 350/700R4 if I keep it under 65 mph.
The problem is that engines are most efficient when they are near their peak torque at wide open throttle, but wind resistance becomes a really big factor at higher speeds. Little engines get better gas mileage because they can operate closer to their peak at normal highway speeds. You'd have to drive extremely fast to get a bigger engine so that it is approaching its peak efficiency, but wind resistance becomes more of a factor and more than cancels out the benefits of running the engine at peak efficiency. Big engines are really only practical if you need the power for pulling heavy loads over mountain passes. I doubt there are too many people on this board that care about being practical though, me included. |
#16876
Figure out how to make it run good on four cyliders?
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
#13 |
Retrofit a "displacement on demand" system like the new v-8's are running, the 345 hp hemi's in the new dod%e charger is suppose to be 24 mpg.
67 short wide 355ci 3 on tree 69 short wide 250ci 3 on tree 68 long wide 283 3 on tree 72 2wd Blazer project 454 5 speed ![]() |
#14 |
Isn't that what Ford does with their F-350?
#15 |
Thats a thought with the Use of Hydro-Gen!
#16 |
Bla Bla Bla! Retrofit might work but thats some big bucks.
#17 |
I am hoping to get around 40 with mine................But it isn't exactly a bolt in deal as you can see below
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
#18 | |
#19 | |
Front suspension is pushed to the limit though ![]() Others used this same engine(6AT3.4) and have averaged 30-35 mpg on the highway WITHOUT an OD................I have OD and steeper rear end gears so it should do well.
#20 | |
December 21, 2012
"!Ama Sua, Ama Kjella, Ama Lllulla!" |
#21 | |
#22 | |
Just Don't Stop!
Nope, no way. TBI is a poor design. Sequential FI is much more effecient. TBI is basically an electronic carb. To get the kind of milage you want you will need a very effecient head design, a great ignition system, and a good amount of overdrive. My tranny has a .50 overdrive in 6th...
#23 |
huh ???
My 396 only gets about 4 mpg. The only time I got 20 mpg was when my 72 had an 84 6.2 diesel in it...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
#24 |
20 mpg with any big block in one of these trucks can not be done.
Tim |
#25 |
Comp Cams 270 or 280 cam, finely tuned Q-jet carb, HEI ignition with MSD 6A box, 3.42 rear gears with an overdrive manual tranny, Ceramic coated exhaust manifolds (not headers), Flowmaster Delta Flow Mufflers with 2.5 inch pipes. You might get 18 or 19.
For the cost to get good mileage, you could leave it like it is and come out about the same. ![]() I had a 90 3/4 ton with a TBI 350 and a 5 spd manual and 3.42 gears and got 20 on the highway and about 18 in the city. Just my .02
