#26 |
More Cowbell....
Rokcrln,
Actually...and I know you don't want to hear this....mine sat an inch or two HIGHER that my stock bench. Kinda' like "COMMAND SEATING". If you want to be lower in the saddle, maybe you should go with buddy buckets. I had a set of those in my truck also, and I sold them to a board member 'cause I was sitting too low & wanted something different.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
#27 |
Re: Tahoe seats in a 72 questions
The links are not working in the above post. Anybody know where I can find the pictures and measurements?
1969 C-10,short bed, I6 250, 3x1 offy, HEI, headers, 5 speed, original paint and family owned! |
#28 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=159857 See post #22
1972 Suburban C20 454/TH700R4, eaton-corporate 4.10 (looking for 3.7) Sold: 71 Cheyenne 20 Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005) |
#29 |
graphic designer
ok, how about in a high-hump truck? 4wd for instance... i heard there were interferance issues.
#30 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Those are very nice looking I have only been able to find the front buckets and even them were $500 that is way more than I would like to spend.. The yard said they get em all the time just have to pick the right day..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#31 |
I agree that the tahoe seats look great but the late model buckets fit great even with the fold down middle sest and you have the benefit if the intergrated seat belts, back and forward adjustment and a ride height about stock.
#32 |
jcfoote60.........you did exactly what I plan to do. Since I don't have any seat belts the belts inthe seat will work for me. Everyone I've run into wants $400 to $500 for a set..........I guess I need to shop harder.
#33 | |
Happy to be here
![]() Join Date: Mar 2000
#34 |
With the 40/20/40 buckets, what is the sacrificed leg room.....I am a tall guy, and pretty much can't afford to give up any leg room....but those buckets look very comfortable!
1969 SS 350 Camaro Sold 2008 1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's ![]() 1980 Chevy Malibu 2 dr Sold 2007 1993 Olds. Cutlass Ciera Wagon Traded 2006 2003 Saturn L200 w/5pd. D/D My list spans 5 decades with One common thread.....GM! |
#35 |
Hey 70chevyfreak, how hard was it to put your seats in. I found a set on Ebay but with out the center console which I would like to have but I dont' know if it would interfere with my floor shift. I have a B&M auto floor shifter.
68 Chevy short wide air cab 4/6 on the drop 327 small block Front disc Frame "c" sectioned Gaylord bed cover |
#36 | |
#37 |
Kudos Putter! I would say that by the frequency of questions and repeated bumps on this thread, that it is headed for the hall of fame ( or at least a great summarized version put in the FAQ section)!!!
BTW - I see the crossed bars under the passenger side of the seat frame when it is flipped up, and they do not look stock (at least not on my 99). What are they for?
Chuck 1972 C-20 Longhorn 402 BB .030" over (409?), curved HEI, RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit 1999 K1500 Suburban (old style) 5.7L Vortec 4L60E "No matter where you go, ........ there you are" |
#38 |
More Cowbell....
Go back and look reallllly hard. I think you are looking at my 4-way lug wrench!!
#39 | |
graphic designer
#40 | ||
Thanks!!
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
#41 | |
More Cowbell....
I tell you what I want to do on mine is to use the rear seat out of a 4-door full-size truck. I know that 2006/2007-classic have them (other years might be similar). The rear seat will still flip in sections, has cup holders, integrated center belt, and is VERY thin on the back....allowing more leg room for taller guys. I just can't find a wrecked truck around here.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 09-05-2008 at 09:22 AM. |
#42 |
Very nice, i really like the Tahoe seat, and the "Tool" box under the flipup. Nice job!!!!!!!!Thanks for the idea i think i will get one for my sons 68.
