Old 07-11-2005, 07:11 AM   #26
4x4Poet
One thing about the caddys in trucks. Most caddy engines had very low-rise intake manifolds to allow for caddy low hoods. Since our trucks have much more hood clearance over the engine, one can run a BBC-style, higher-rise aftermarket intake manifold on a caddy motor for more performance and maybe better mileage. Nice advantage for our trucks.
Also, caddy engines were made to run sah-moooth. The valve train stuff on the heads is really quiet and the crank and bottom end is super well balanced. Neat engines, IMO. Just a little tough, parts wise.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 07-11-2005, 12:50 PM   #27
FUNMUDDER
FUNMUDDER's Avatar
you can but a flywheel for a caddy so you can use a clutch, but it is 275-375 bucks from some big caddy hot rod shop. I think you can use a 11 orr 12 inch heavy-duty clutch with it. And you can buy a adapter from jegs that goes from a chevy tranny to a buick, olds,caddy or pontiac engine for about 60 bucks. so to use the granny gear tranny, it will set you back quite a chunk of change.
FUNMUDDER is offline   Reply With Quote
Old 07-11-2005, 01:34 PM   #28
FUNMUDDER
FUNMUDDER's Avatar
here is the link for the flywheel. 325 dollars.
http://www.cad500parts.com/catalog/index.htm
Old 07-12-2005, 05:56 AM   #29
GMC AMI
GMC AMI's Avatar
Thumbs up
Thanks for sharing that link!
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 07-12-2005, 11:56 AM   #30
Jason915
My 355 has real good low end torque for a small block its got a 4x4 Comp cam and an edlebrock EPS intake and 4.10's. With no load it seems like a stock BBC put 1500# on it and then you can tell it's just a SBC I want more power and better MPG I would like to build a 383 someday.
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's
1970 K5 TBI conversion lifted etc SOLD
1968 C20 camper truck SOLD
“To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder
Jason915 is offline   Reply With Quote
Old 09-23-2005, 01:06 PM   #31
FUNMUDDER
FUNMUDDER's Avatar
I'm going to soup up a 327,350, stroked 350 or 400 sbc and run a granny gear tranny.........thanks for the input.
Jake
Old 09-23-2005, 03:53 PM   #32
1969 C/K CST
A.K.A- Crummy
1969 C/K CST's Avatar
Smallblock-Bigblock torque. http://www.crateenginedepot.com/stor...9101-P7C2.aspx
2003 Silverado Z71 Are fishermen all liars?
1969 C/K CST is offline   Reply With Quote
Old 09-23-2005, 07:01 PM   #33
FUNMUDDER
FUNMUDDER's Avatar
Too much moolah to spend on a engine.
