Old 07-08-2005, 01:28 PM   #26
FirstGen
Just Don't Stop!
FirstGen's Avatar
Originally Posted by 68LSS1
I agree with FirstGen (almost) and I didn't mean to put the Megasquirt comparable to the others because it's not even close. Note on the engine above is still uses a stock ECu so if you have access to a good tuner you can push them pretty far. As far as the throttle by wire I'd use it. One question though. If he doesn't use it, won't he have to get another ECU or flash that ECU with a model year program that had the cable driven throttle body instead of electronic? I didn't know MSD had come out with a coil but at $75 per I think I'll pass. And as far as the thread for Street & Performance that lilred67 provided, they have some good stuff but a lot of it is a lttle on the high side (price wise). And Rob, like was mentioned, not a super deal but not bad either. I would compare it to buying a crate engine also. Get it and one start saving for one of the new 6L80E's. Throw the Shrifter on there and drive the crap out of it..... Sorry, I get carried away.
No you can reflash the PCM and modify the harness to go to a cable TB. Alot of the hard core vette guys do this. It eliminates alot of computer problems/trouble that comes into play when you get some serious power adders and big cams.
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 07-10-2005, 03:53 PM   #27
Joe67
67 is sold
Here is a good thread with LS1 motor swap info:
http://67-72chevytrucks.com/vboard/s....php3?t=145746
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 07-22-2005, 09:59 PM   #28
Hart_Rod
Hart_Rod's Avatar
Does anyone know if you can buy software to program the computer yourself? I don't like the thought of spending $300-350 to have someone change just the tires size/gear ratio and remove egr. I think we have enough people on this board that are interested in doing this that it might be worth buying the software.
Rob
Hart_Rod is offline   Reply With Quote
Old 07-22-2005, 11:54 PM   #29
Tim240Z
Tim240Z's Avatar
TunerCat has released the LS based software, although I don't believe they have updated their site yet.....contact them directly at TC@tunercat.com
1972 Suburban C20
454/TH700R4, eaton-corporate 4.10 (looking for 3.7)
Sold: 71 Cheyenne 20
Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005)
Tim240Z is offline   Reply With Quote
Old 07-23-2005, 02:01 AM   #30
FirstGen
Just Don't Stop!
FirstGen's Avatar
No tunercat has not released theirs yet.
There are many options however they are VIN limited.
LS1Edit
HPTuners
AutoTap EFI Live
Etc
LS1Edit is the most common and is $550 for the programs and 2 VINs I believe and around 4000 for a dealer license.
TT LSA/6L90e/9"
Old 07-23-2005, 03:19 AM   #31
68LSS1
68LSS1's Avatar
LS1Edit
HPTuners
AutoTap EFI Live
Etc
I'm pretty sure that is only one VIN on the price for LS1edit. It's not the easiest to use for a first time tuner but it does work quite well. I have no working knowledge of the others.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 07-23-2005, 10:21 AM   #32
FirstGen
Just Don't Stop!
FirstGen's Avatar
Actually it's $450 for one PCM and $100 for additional PCMs. They started to do that to keep up with HPTuners. HPTuners is pretty much exactly like LS1Edit except it is in color and has the ability to data log which LS1Edit does NOT! HPTuners is $550 but allows you to use 3 VIN's for 2 year models - or at least that is what they offered when it first came out.
I've used LS1Edit quite a bit and it's pretty straight forward but don't expect any help from the vendor's: www.carputing.com
TT LSA/6L90e/9"
Old 07-23-2005, 10:04 PM   #33
GMCGRANDS
Hi Rob
I have a 6.0L LQ4 with a 4L80E in my 72' GMC. The Truck is still under construction. But I can probably answer most of the mounting questions. Plus my previous and current daily driver trucks are both 6.0L trucks. I love the 6.0L and the 4L80E is about the strongest 4spd automatic you will find.
Like 68LSS1 Im using the f-body oil pan. I had the truck pan in and changed due to my low ride height. The truck pan hung about 3 to 4" below the front crossmember and was the lowest part on the truck. With the F-body pan its even with the crossmember. Keep in mind both 68LSS1 and myself are both running Fatman front suspensions. Im also running dropped spindles and have the fatman crossmember slid forward on the frame rails. My cab is a low hump and the transmisson is a tight fit. The problem area is where the firewall and cab floor meet. The pinch weld were they come together will need to be trimmed. The other option is to shim the cab mounts up slightly. I made my own motor mount adapters. I wanted my engine low and back towards the firewall. You might avoid this problem if you slide the engine forward a little as long as the oil pan sump can clear the cross member. I played with my mounting location several times to get it were I wanted. Keep in mind the trans is electronically controlled as well. To my knowledge Mega Squirt has no provisons for trans control. In my opinon the factory PCM is the best option at the moment. The cost of FAST, Accell and most others is too high. The factory PCM can be programed to accomidate most mods you may have planned. Spend some time at LS1tech.com.(the Best), LS1trucks, LS2.com, LS1.com theres lots of good info out there. The swaps are not cheap but I think you will be pleased.
I bought my engine and trans with all accessories, pcm, wiring harness etc. out a junkyard. The donor was a 2002 Chevy 2500 2wd. with 27000 miles. Cost me $2200. If you have any other questions give me a shout.
Firstgen is right about the LQ4 and LQ9 but the current Sierra Denali trucks and Yukon Denali's have the LQ9 345 hp engine along with 03',& 04' VHO version of Chevy and GMC 2wd extended cabs (Pretty rare), Chevy SS trucks. LQ4,s have the aluminum heads on 2001 and later and can be found in lots of Vans & trucks (1500HD, 2500, 2500HD, 3500)
Mark
72'GMC Sierra Grande 2wd SWB, Fatman stageV IFS, 6.0 liter LQ4 Gen 3 and 4L80E under construction
05' GMC Sierra Denali LQ9
GMCGRANDS is offline   Reply With Quote
Old 08-01-2005, 08:47 PM   #34
Hart_Rod
Hart_Rod's Avatar
Mark thanks for all the info. Do you have any pics of your project?
Rob
Old 08-01-2005, 09:30 PM   #35
Custom 68
Custom 68's Avatar
I bought a 5.3 and 4l60e tranny with 18000 miles for 1500 dollars complete AC and all. I then proceeded to get a new harness (still have the old one) and computer reprogramed. I dont have any good pics yet but it runs real strong. I wanted a 6.0 but the yard didnt have any at the time
Good luck
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 08-02-2005, 02:48 AM   #36
Autometer
Autometer's Avatar
I bought a LQ4 from work and will be picking up a 4L80 once the SO gives the green light. I was thinking to put that into my '51 or the '71. I don't think I could part the 402/TH400 combo out of the '71 though.
'05 Silverado
'02 Avalanche
'85 C10
'71 C10
'51 3100
Autometer is offline   Reply With Quote
