Old 07-28-2005, 03:03 PM   #26
FirstGen
Just Don't Stop!
FirstGen's Avatar
Originally Posted by fastbagged68
Flipping ball joints wont change the lenght of the control arm. If you want more camber take out your shims if you haven't yet.
No shims left to take out. Actually it should push or pull the ball joint a small amount in one direction or the other at that same ride height. Think about it, well it might be different for you but with my tubular uppers there is a 1/4" thick plate the ball joint mount to... if you were to say put the ball joint on the bottom of that 1/4" you effectively move the ball joint because with a lowered truck the angle of the control arm is not perpendicular with the crossmember anymore. I'm not talking about a huge difference but I just need another degree or two...
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 07-28-2005, 05:04 PM   #27
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Do a search to see if the Van steering box are raised up. If you want I will have my buddy take a picture of it.
I can save you the work of looking. Van boxes ARE mounted higher.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-28-2005, 05:04 PM   #28
69 longhorn
I havent flipped my upper arms yet, but have looked at the idea. It looks to me like the flip on the STOCK arms will change the angle enough to pull the top of the spindle inward somewhat. If you are running tubular upper arms, I think most are built a little longer to compensate for the geometry issues on the short spring, or bag drop. on the tube arms,I dont think you will move things very much , just by bolting the balljoint to the bottom side of the arm.....that just a guess tho! I would like to hear a little more on the subject L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
