Old 07-31-2005, 12:02 PM   #26
mvpco
Holes in dash cut for A/C
Here are a few pics of the A/C Dash holes cut out this weekend. took about 30 minutes each hole. I used the Black & Decker Rotory tool and about 15 cutting disks. Worked real well if you go real slow.....
Now I just need the correct duct hose for side vents. The ones I purchased were about 1/4 inch to small...any ideas???
I also made some templates from the cut out peice for furture use.
Jeff Smith
http://www.mvpc.com/1972chevy.htm
mvpco is offline   Reply With Quote
Old 07-31-2005, 07:37 PM   #27
john
member #16
john's Avatar
Jeff http://www.oldairproducts.com/shop/index.php has adapters to fit the side vent hoses. Ask for the ones made to fit 67-72 chev vents that come in their installation kits. John
john is offline   Reply With Quote
Old 08-01-2005, 07:36 AM   #28
mvpco
Thanks!
Thanks John! will do
Jeff
Old 08-01-2005, 04:40 PM   #29
mvpco
A/C Ducts
Thanks John!!
I ordered form Old Air Products & they knew what I was talking about and there is a 2 3/4 inch duct, Whew! thought I was missing something.
Thanks for the help! cant wait to fit, then tear it all apart and get it painted..sweeeeeet!
Jeff Smith
Pensacola, FL
850-475-5030
Old 08-03-2005, 05:48 PM   #30
mvpco
A/C Shroud and Clutch Fan?
HI All!
Question: When adding a factory A/C unit to a non-Factory truck(72 Chevy), How important is to use the A/C Shroud and clutch Fan? Or can I keep the ones on there from when it was non Air?
Jeff Smith
Pensacola, FL
Old 08-05-2005, 08:49 PM   #31
mvpco
Clutch Fan?
How important is clutch fan and A/C Shroud when adding A/C to non A/c truck???
Jeff Smith
