Old 10-28-2005, 02:26 PM   #26
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: How do you adjust the rear end on a 6 inch drop?
Originally Posted by yellow69
Well, I took my truck up to a buddy of mine's shop to get the upper shock mount area fixed and welded. I asked him to see if he could look at the rear end and see if he could take a shot at it. He found that the passenger side of the rear end has been welded to the U-Bolt bottom bracket.
That might make it a little hard to move the rear end.
OK, if I'm reading it how I think you mean it, then that won't matter. Are you saying that the saddle is welded to the axle housing? If so, it's supposed to be. Your U-bolts, rear end axle housing, and trailing arm are bolted together and you don't need to mess with those to worry about the panhard bar. The WHOLE rear end (axle housing, trailing arms, U-bolts, everything) needs to be moved to center it. There's no need to disassemble any of the rear end components to do this. It will help if you remove the shocks from the lower mounts, but thats it.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
