#26 |
72 BB C30 Super LongHorn
![]() Join Date: Nov 2002
If you need a cable, take a long cable out of a donor car, cut it down and angle cut the ends so that it feeds correctly into the back of the gear it is needed for....
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS ![]() Last edited by RPOZ11; 10-09-2005 at 09:53 PM. |
#27 | |
#28 | ||
its all about the +6 inches
#29 |
That process is called Swedging!
Most likely these were hydraulically pressed on a machine to square that up from the round cable shape to this sqaure shape! Throttle cable places that repop Camaro stuff can do this for you! And...This ain't cheap! Sorry! ![]()
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS ![]() Last edited by RPOZ11; 10-09-2005 at 09:57 PM. |
#30 |
I kinda figured it was a press that did this. Even so, I tried using a shop press, vice grips, even a hammer.
Yeah, i still need a cable. ![]() I thought I hit the jack pot in the junk yard, I found a later model speedo cable, with a plastic end cap on the cable. it looked like it was placed on a predetermined cut to length cable. I grabbed this, and figured i could simply pop the end off of the cable, cut to the length I needed, and glue it back on. Nope. That didn't work either. ![]() |
#31 | |
#32 |
Both ends of the cable were square. I'm talkin the cable it's self, not the housing.Just like the one you pictured...
Tomorow, i'll look at mine and see if I am mistaken on cable length...and see if there is a way I could use a 4 footer if mine was shorter. What would you want for that? Last edited by Longhorn Man; 10-09-2005 at 11:56 PM. |
#33 |
I wonder that you might check speedo cable lengths from car to car and find one that is relatively close, and just assume the extra inch(s) in order for it to be operable once again!
Speedo cables on the Camaros were different from application to application, and quite possibly may result in a length useable in our Trucks...It's a thought!
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS ![]() Last edited by RPOZ11; 10-10-2005 at 12:12 AM. |
#34 | |
72 Jimmy custom 72 Sub CST 79 2 ton Camper |
#35 |
If you have an end to end measurement for the cable, and end to end measurement for the complete cable with jacketed housing, we could start looking for you from there......
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS ![]() |
#36 |
OK, it took me an extra day...but I just measured my cable.
30 inches...so we are talkin less than 3 foot. I can compensateup to about 6 inches either way by relocating my transducer for or aft on the fenderwell. but i can't see milking a foot out of it though. ![]() |
