#26 |
Your UncleBen
![]() Join Date: Dec 2002
Is that a factory Sunshell? That is the weak leagth in a factory 700R4...
Check out... www.700r4.com also know as bowtieoverdrives.com They have alot of good info and excellent parts for sale. lata CHRIS
68 C10 shortbed -- Street/Strip ![]() |
#27 |
That's some impressive twist on the what looks like the TQ housing! (I'm no fan of autos and even less knowledgeable about them)
But, in line with masterbeavis' comments, I've often read on forums like this one that the 4L80Es are much stronger than even built 700Rs. And built 4L80Es can take some serious abuse. Might be worth it in the long run to save up to go heavier duty so you can forget about tranny troubles for a while. Maybe a long while if you don't try to show off to '05 Stangs. ![]()
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. Last edited by 4x4Poet; 09-11-2005 at 04:27 AM. |
#28 |
Can I run a 4L80E behind a carbed motor ? Anyone know if a 94 astro would have that tranny ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#29 |
Well I have never seen the inside of a tranny before thanks for voluntering the pics
sorry about the loss thats it going to be no fun to fix
1970 Short Stepside----Process of Restoring 1983 1/2 Silverado |
#30 |
94 astro wouldnt have a 4l80e. its a bit expensive to get the standalone electronics to work with a carbed motor as well.you would need to find a 3/4 ton or heavier truck to get a 4l80e. then get a standalone control unit from tci which is 1200 bucks on its own.i have had two seperate ones that refused to communicate with the laptop.real pita
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
#31 |
Its Magically Delicious
Thats some awful carnage there !!!... glad no one was hurt
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
#32 |
its all about the +6 inches
cableguy is right. The 4L80E is an outstanding tranny, however it makes the work doing up a 700R4 look like fun. You can get a stand alone harness and computer out of a certian year (I have NFC WHAT year) diesel truck/burb...but they are far and few between. (When was the last time you saw a 6.2/6.5 truck in the bone yard...and what was left on it?)
#33 |
but if you were to find a diesel computer it has to be completely reprogrammed for the gas engine more cash there
#34 |
ahhh, I did not know that. Thanks
#35 | |
94 Astro will have a 4L60E. About the only vehicles with 4L80E's....something with a diesel or a big block, 1 ton, or special ordered. The E part of 4L80E is what is the kicker....everything is controlled electronically....upshift, line pressure, blah, blah, blah.... Why not build Turbo 400 and use a switch pitch torque converter? |
#36 |
blood type; Retumbo
that is possibly the worst carnage i have ever seen. makes me wonder if the TV cable was adjusted correctly. these things can build LOTS of pressure and in the one pic it looks like she split at the end of the input shaft.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
#37 |
that blows(no pun intended)
-Steve |
#38 | |
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
#39 |
it will work after it is reprogrammed the diesel has totally different shift points than a gas motor
#40 |
Sheesh… talk about no way to limp home. I believe the technical term for that is “total spontaneous disassembly”.
700R4 or otherwise…. that just ain’t right. I’d be tempted to lay it all out in front of the builders shop door and guard the pile like a rabid dog until I had a check in hand.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
#41 |
Cantankerous Geezer
Since you bent the shaft, I would suggest checking the pinion bearing.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
#42 |
67-72 Addict!
Sorry to hear that Mario. Glad nobody got hurt.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#43 |
PROJECT 7DEUCE
Damn that is the biggest tranny gernade I have ever seen...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#44 |
Born a Chevy Man
Sorry to hear about your mishap. Glad your dog was not hurt. Part could have come through the floor. What year tranny was it. I have heard pre '87 and not as good as '87 on.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) ![]() ![]() If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! ![]() GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
#45 |
COOL, all from a stocker. Duece better put a block under the pedal, or we will have more carnage in Canada.
67- 72 Parts collecter |
#46 |
![]() Join Date: Jan 2002
I'm surprised the guy with the 05 Mustang didn't file a claim against your insurance company. To be honest if someone's car shedded parts in front of my car and damaged it I would be asking for the name of their insurer.
71 Cheyenne Super 4X4 SB 72 Cheyenne Super 4X4 SB 72 Cheyenne 4X4 SB |
#47 |
Professional Grade
That my friends, is why I'll pay the extra dough up front to get a 4l80e for my GMC. You save that money on the first tranny explosion that you prevented.
I plan to use the diesel shifter, I know a few guys who will re-program one for me. They are relatively simple to re-program as far as I am aware. They apparantly use a prom similar to any older GM ECM, and its just a matter of setting the shift table up for a gasoline engine rather than a diesel engine, which means that a guy has to do a couple of different tables, depending on the TPS, VSS, etc.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
#48 |
I'll have to keep my eyes out in the Uxbridge area for an oil slick. At least you had fun with it for most of the summer. Good luck on the repairs.
#49 |
You will see the puddle for sure. Hwy 48 and Davis drive. Go west towards newmarket on Davis Drive and about 40 feet after the lights there is a huge puddle of fluid. I marked my spot.
I went to the shop today and showed the tranny shop the pitcures of the damage. I brought the dented drive shaft and a milk crate full of parts I picked up off the road and the tranny. He is not going to take care of anything but rebuild the tranny and in his words "it will be cheep" I hope when I show up it's Free. I still need to gater a god chunk of cash just to get the tranny back in the truck.
#50 |
he should pay for everything. that case had to be cracked when he built the unit.
