Old 10-04-2005, 05:28 PM   #26
love it loud
Calibration Engineer
love it loud's Avatar
would you be able to get a good picture of the watts link setup sometime?
CANADIAN CONNECTION
love it loud is offline   Reply With Quote
Old 10-26-2005, 03:01 PM   #27
DM310
Re: new pics of suspension
Heres a new pic of it on the ground. Notice the rear is a little higher which is b/c the rear tires are 30" and the fronts are 28". When I get my new tires which will be 27.5" it will level out
66 C10 (under construction)
1.5" crossmember drop
2" Z'ed frame
8" rear notch
Watts-link
Bagged
DJM 3" spindles
DM310 is offline   Reply With Quote
Old 10-27-2005, 09:30 PM   #28
qksilver
I have a question about the location of the bags. Why so close to the pivot point? Withe the bags mounted further back wouldn't the trailing arms be less stress, and would the suspension have more travel? I ask because of leverage........ I have built a couple of meduim duty tow trucks using air bags for the suspension and they seem to work better the farther back we could go from the pivot point. Much less stress and better ride.
Steve
qksilver is offline   Reply With Quote
Old 10-27-2005, 09:35 PM   #29
phantom dually
Project92 SWB stepside
phantom dually's Avatar
lookin good!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 10-27-2005, 10:17 PM   #30
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Steve
Not to flame you, but that has already been discussed in THIS thread......Did you read any of it or did ya just look at the pictures like I usually do? hehehe
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 10-27-2005, 11:11 PM   #31
SCOTI
SCOTI's Avatar
Ok . . .... I read the posts & looked @ the pics but I still can't figure out why the heck anyone would need so much travel from the rear when you can only get 1/3 of it up front.
I guess if you wanted extreme lift for the sake of status, that's one thing.... but I just don't see any practical* reasoning for it. I can see moving them slightly forward or backward in an attempt to adjust the ride quality. But, like anything, too much of a good thing isn't necessarily good itself. Is this mod just for bragging rights?
Regardless, the truck looks pretty slick from the pics & I look forward to seeing it w/some more sheetmetal hung. Nice job!
*Disclaimer: Although the word 'practical' itself doesn't normally co-exist w/extreme-drop air ride suspensions, its context fit my statement.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-27-2005, 11:40 PM   #32
67Fleet
67Fleet's Avatar
Well, I have my reservations about the trailing arms and/or the bags holding up to that much stress, but guess we'll see. I just pray it doesn't come apart at high speed on him. That would be a disaster.
-Bret
Old 10-30-2005, 02:05 AM   #33
DM310
If I did not feel safe I would have not built it. No its not for bragging rights. Thats the only spot I could fit them on the arms w/o interference of the frame w/ the truck that low. Yes I could have installed a step notch but I didnt. The arms are going to be reinforced
2" Z'ed frame
8" rear notch
Watts-link
Bagged
DJM 3" spindles
Old 10-30-2005, 06:01 PM   #34
SCOTI
SCOTI's Avatar
Originally Posted by DM310
.... No its not for bragging rights. Thats the only spot I could fit them on the arms w/o interference of the frame w/ the truck that low.
Thanks for the clarification. Keep us posted on your progress.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-13-2005, 09:53 AM   #35
mike nutt
69fatmotor
mike nutt's Avatar
assuming from the look of suspension in the truck it is going to show truck/cruizer and will haul nothing more a couple of passengers and maybe a cooler or two , so the set up youve got in the pictures should work fine ,the only suggestion i have would be to weld upthe seams,top and bottom of the trailing arms
mike nutt is offline   Reply With Quote
Old 04-09-2007, 07:04 AM   #36
L0WRIDE
L0WRIDE's Avatar
hows the project going DM310 got any new pics
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN
62 HARDTOP NOVA
65 CHEVROLET BB LWB FLEETSIDE
90 CHEVROLET EXTRA CAB
CHEVY ONLY - NZ Chapter
http://67-72chevytrucks.com/vboard/s...d.php?t=137984
L0WRIDE is offline   Reply With Quote
Old 04-10-2007, 01:05 PM   #37
DM310
Couple of updates, I redid the rear notch and a couple of other things. I will take some pics when I finish. The cab and bed are in the body shop getting paint.
2" Z'ed frame
8" rear notch
Watts-link
Bagged
DJM 3" spindles
Old 04-12-2007, 04:10 AM   #38
L0WRIDE
L0WRIDE's Avatar
lookin forward to seeing them !!!what size rims you running???
62 HARDTOP NOVA
Old 04-12-2007, 05:20 AM   #39
64shortc10
64shortc10's Avatar
Looks good lets see some new pics. I wouldn't worry about the bag location I had an S-10 with a 2-link with 2600lb. slambags mounted like the same distance from the piviot point as yours with no problems. The only thing with them that close is it does not take alot of pressure to lift the back up so driving real low it tends to feel like your on a ocean liner boat. Where are your shocks mounted and what kind are they? Again it looks good, I want to see it with the front sheet metal back on and some 5 spoke 22's
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 04-12-2007, 07:27 PM   #40
bedsled71
bedsled71's Avatar
truck looks really good and dont let anyone freak you out about the pivot point. if you reinforce your arms they will be just fine. your not towing a 5th wheel with that anyways . it will be fine
bedsled71 is offline   Reply With Quote
