Old 09-12-2005, 03:27 PM   #26
72 longhorn BB
72 longhorn BB's Avatar
Try this
Go to:
www.raintracker.com
if you want to get more speeds out of your wipers
This rain sensor will do the trick. Just installed one on my Neon - love it.
Next up, install on teh C-20
Chuck
1972 C-20 Longhorn
402 BB .030" over (409?), curved HEI,
RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit
1999 K1500 Suburban (old style)
5.7L Vortec
4L60E
"No matter where you go, ........ there you are"
72 longhorn BB is offline   Reply With Quote
Old 09-12-2005, 04:48 PM   #27
86swb
Born a Chevy Man
86swb's Avatar
This rain tracker. How hard was it to install and how long did it take you? Will this work or the '67-'87 trucks?
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 09-13-2005, 01:57 AM   #28
masterbeavis
Having issues
masterbeavis's Avatar
Furthest their catalog/compatibility goes is to '85
Quando Omni Flunkus Moritati.
The Man's Prayer: "I'm a man, but I can change, if I have to, I guess."
masterbeavis is offline   Reply With Quote
Old 09-13-2005, 05:50 AM   #29
GMC Jim
GMC Jim's Avatar
Per GM Shop Manual; the heater blower specs are:- RPM- 2550 to 2950; 13.5 volts @ 6.25 amps max. Air conditioning blower specs are:- RPM- 3700 min.; 15.5 amps max.....As these specs indicate; the blower used with air conditioning is much more powerful. Fuses used with heater only is 15 amp.; air cond. is 25 amp. Marine standards allow 14 guage wiring for non-critical loads of 20 amps at a distance of 10 feet or less. Wiring diagrams show # 12 wire from fuse block to blower motor relay and from the relay to the blower used with trucks with air conditioning, however I have seen # 12 wiring on non air trucks. In any case; replace the existing heater fuse with 20 amp. and the wiring will have no problem sustaining the extra load of the heavy duty blower motor. Be sure sure to examine the wiring for any fraying and replace. If replacement is desired; use # 12 wire from fuse block to relay and from relay to blower motor. Using #12 wire will minimize voltage drop for more efficient blower operation.
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
Old 09-13-2005, 06:58 AM   #30
al's71gmc
4 eyed fever
al's71gmc's Avatar
I just went out to the parking lot and fixed my heater!! Well fixed is a little strong, the plug in from the blower was undone. BTW I checked the fuse box first and mine's got a 25 amp fuse in it already. It's marked on the box for 25, and it's a non ac. Anyway, I've got heat and it might even defrost the windshield now!!
1971 GMC 2500 4x4
1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto.
4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!!
al's71gmc is offline   Reply With Quote
Old 09-13-2005, 07:32 AM   #31
86swb
Born a Chevy Man
86swb's Avatar
They can go back farther but they would need your wireing diagram for your year of truck.
Old 09-13-2005, 08:12 AM   #32
72 longhorn BB
It should be able to work
The method of operation is pretty straight forward. If I can get a copy of the schematice for our trucks, I'll make a diagram and post it for all to use.
I LOVE how it works on my Neon - all you do is flip a switch and it will wipe as much, or as little as needed.
It automatically varies the wiper speed from slow puled wipes, to faster pulsed wipes, then to constant low speed and to constant high speed - all depending on how much water it senses on the windshield.
One thing though; it needs to be placed within only ONE wipe pattern - preferably the passenger side near the center mirror - and also 2" inside the arc of the wiper tip.
I love it and will install it as soon as I can get a vehicle schematic to work out the interface.
Chuck
1972 C-20 Longhorn
5.7L Vortec
4L60E
Old 09-13-2005, 09:11 AM   #33
86swb
Born a Chevy Man
86swb's Avatar
Do you think this is something the advarge guy can install?
Old 09-13-2005, 11:43 AM   #34
72 longhorn BB
sure it can...
sure it can , as long as I can get ahold of the wiper schematic for 67-72 chev trucks, I can make a wiring diagram.
Does anyone have a schematic of the truck wiring?
Chuck
1972 C-20 Longhorn
5.7L Vortec
4L60E
