10-04-2005, 08:56 AM | #26 |
I havent gotten mine aligned yet, so it is off A LOT. i dont even have any shims in but after i get that done it should be a lot better. All the measurements I took before and after the z came out the same. I know that S-10s do the same when you drop em. A good friend of mine is going to do a laser alignment on it hopefully this week and then I'll have a better idea of how much it moves back layed out. thanks for pointing it out though
10-04-2005, 11:41 AM | #27 | |
Señor Member
10-04-2005, 12:23 PM | #28 |
I see whatyou mean. What if you would roll the crossmember forward a few degree, keeping it in the same place front to back but rolling it forward, that would decrease the kpi a little, If im thinking correctly. I dont know what that would do to the steering geometry, or ride quilty but it might be an option. IF it would work. I neverr really thought about it that much before but now you have me thinking. I guess a mustang II front suspension is always an option but I know I dont want to drop the money If I can think about long enough and make something work and work well. Well if you come up with something let me know as will I
L8r |
10-04-2005, 12:46 PM | #29 |
You do not want to roll the crossmember. The arms are set up on an angle for anti-dive. I moved my crossmember up. But I have a 63 so mine is not as noticeable as 67-72.
11-24-2005, 09:51 PM | #30 |
Re: Laying frame on a 67
is there anyway that you could make me some of the notches that extend to clear the stock trailing arms(DroppedChoppedPanel
BADPANL) i would pay if the price is right i like that setup let me know |
10-31-2008, 11:38 PM | #31 |
Hello,
i have a 68 pick up and am planing on laying frame. the truck currently has factory A/C does any one know it the tire (29 inches tall) will hit the A/C box or if it will work? |
11-01-2008, 12:17 AM | #32 |
67-72 parts collector,…
XXL,... The easiest way I can figure out,... is to make your "Z" cuts on a 45 degree angle. That way when you raise the crossmember frame section up,... it will also move forward. (ie 1.5" up = 1.5" forward) If you need to go up MORE than you go FORWARD,... that will require a different angle.
11-01-2008, 12:46 PM | #33 |
PROJECT 7DEUCE
Holy old thread batman..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-14-2008, 04:16 PM | #34 |
and a few others
pretty good one, although these guys are probably in the retirement home by now.
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
