#26 | |
Shaved '77 Silverado |
#27 |
Well, I replaced the ignition module (the last time this did this...I determined I was getting gas, but no spark....); and so far this fixed the problem.....
"Fighting for our freedoms....." |
#28 |
No it started a while after i put in the engine.. the engine is brand new.. ( 8 months old ) .. I am going to try the ignition module this weekend if i have time.. Its only $50..
#29 | |
#30 |
Check out GMTrucks.org
Usually when the module goes, it goes all the way and you can't get it started at all. But, they do flakey things some times.
A quick way to tell if it is the module or anything electrical is to pull a spark plug. Connect it back to the wire and ground the electrode to the block and have someone turn it over. If you see a spark, you are good. You can also hook up a timing light if you have one to see if your are getting spark. If you are seeing spark, I would guess everything electrical is ok. My burb had the same problems you have until I rebuilt the quadrajet. Maybe something is clogged or out of adjustment. |
#31 | |
#32 | |
#33 | |
#34 |
First with my truck (although it is the straight 6 with the 2bbl rochester) I have to pump the gas many times saaaaaay 10? because the pumps bad, fires right up after that though. Secondly, if the starter was off I believe gm starters need shimmed to line up properly? Don't know if that would effect your problem or not, it just made the one in my brothers pontiac (85 parisienne 305) make a slightly more sharp sound upon start up. Doubt any of this will help but just throwing ideas out there.
Matt
1981 GMC Sierra 1500 4.1L I6 1985 GMC Sierra 1500 5.0L V8 (Parts Truck) ![]() Last edited by Matt_305; 10-14-2005 at 11:08 PM. |
#35 |
ureckmefixit2@cox.net
Re: Truck does not start well..?
May be the choke need to be leaned out a little?
That's U RECK ME FIX it 2 74 Chevy Short Bed 355ci Sportsman II 64cc Angle Plug Crower Custom Grind .462in .486ex Dyno Test 422hp @ 5600 And it's got a Holley 3.73 Gears 12 Bolt 3.73 w/Posi 700R4 Going In I'm a Body Man So There! That's why it's not painted |
#36 |
ya.. might be the need to be leaned out. .. Im pretty sure the pump is fine..
I wish try yout guys' ideas tonight though. |
