10-20-2005, 09:10 AM | #26 |
Re: hei
i don't thinks clearneane is going to be a problem in my truck i got an good 3 inches from the back of the distributor to the firewall if not more
10-20-2005, 12:27 PM | #27 |
Re: hei
I've got a '79 350 with performance mods (cam, Sportsman II heads, etc). Its been balanced and I've been told that a 6500 rpm red line is acceptable. I use 6000 (I think 6500 would be pushing it too much). My HEI ignition module burns out every 3-6 months. 3 months if I'm driving a lot, 6 if I'm not.
I figure the burn out is either reving it to 6000 occasionally (it pulls strong to 6000-6500 or more. I chicken out before it poops out) OR due to voltage problems. I have a lead from the unfused spade on the fuse block directly to the proper spade on the distributer. A local mechanic told me to put a resistor in that line as anything over 12v will burn it out. I've also heard that less than the full 12.5v-14v output from the alternator will burn it out. Its only $20 for a new one, but a pain in the rear to keep replacing them. Any ideas on why mine keeps going out?
"Truck" '67 small window '79 350 .030 over, LT1 "clone" Last edited by Lobo'74; 10-20-2005 at 12:27 PM. |
10-20-2005, 01:33 PM | #28 |
Questionable
Re: hei
One reason might be Excess voltage. The other might be not having added the extra (self-supplied) ground strap from the coil to the grounding post. When I say self-supplied, I mean this doesn't come with the coil, but it tells you to add it in the instructions.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
10-21-2005, 09:20 PM | #29 |
Re: hei
OK. Coil is inside the distributor (I'm sure you know that, no offense ment) , where do I attach the ground wire to get contact with the coil?
"Truck" '67 small window '79 350 .030 over, LT1 "clone" |
10-21-2005, 10:07 PM | #30 |
Re: hei
Hey somebody said something about having 14 volts and a different wire size.I just installed one in my 72 and used the original wire and it tested out as having 12.8 volts or something like that.Question is .If i run a larger wire will that give me the 14 volts or should i do something different.
10-22-2005, 12:02 PM | #31 | |
Questionable
Re: hei
10-23-2005, 07:48 AM | #32 |
Still Green but learning
Re: hei
If its not balls out Horse power your going for, and isntead you are looking for a reliable ignition system with a slight HP advantage and a bone stock look. A friend installed some Plitonixs sp?? electronic points, he put a new Coil in that looks stock and did the rewire to get more voltage. Wala, a reliable HEI system, same stock distributor with cap, it looks bone stock. Im going to do it one day. O yea, and when shopping for these if you do a complete swap, soem of the HEI system are pretty tall at the distributor, clearance with the Air cleaner on these engines can be an issue. Although I did see one at a buddies house on a 70 GMC that was more flat and wide then tall.
just my .02
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
10-23-2005, 10:06 PM | #33 |
Questionable
Re: hei
I think that's Petronix or Petronics.
