#26 |
Well
The corporate 3/4 ton and 1 ton diffs had 17 spline. the heavy duty 11000 lbs special order 1 ton diff had 27 spline. The dana 60 in these trucks had 30 spline. BB 3/4 tons had standard equipment 3.54 ratio dana 60's. Optional diffs and ratios could be ordered. In some cases a posi /locker was not an available option if you had a BB. My BB 72 1 ton duallie has a eaton diff 4.10 and detroit locker factory optioned that way...on the glove box. You could get either dana or corporate under a 3/4 4x4 or a 3/4 ton 2 wd. Leafs were available under both also..but no coils under a 4x4 or a longhorn chassied unit. Last edited by Rod; 10-09-2005 at 12:05 AM. |
#27 |
I'd guess that GM used two different axles in 3/4 ton 2wds because they could order the coil Eaton 2wd axles with just coil spring trailing arm perches and then order D60s with just leaf spring perches. Might have saved money going all one way with each axle. Also, the Eaton's all welded plate axle housing accomdates welded on brackets better, such as for locating arms.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
#28 |
BTW, due in most part to some wordy instigator
![]() http://67-72chevytrucks.com/vboard/s....php3?t=172827
#29 |
My 71 had a dana 60 in it (my daughter blew it up doing burnouts) I replaced it with a GM14 bolt, had to move the spring mounts and fab shock mounts.
#30 |
72 BB C30 Super LongHorn
![]() Join Date: Nov 2002
4X4 Poet:
You've done some time investigating and investing in all of this info! I guess I will crawl under the LongHorn and take a few images in the morning of what I have. I do know that that side bolt is there on the drivers side of the pinion/center-section. The brakes I know are HUGE on this thing; rather surprised me the first time I crawled under her when I was buying it! With it being ordered as a 1-ton C/30, even the shocks have overload coil springs on them! I peered at a center-section HO set-up a few weeks ago, passed on it because I really didnt know what I was looking at! I do suppose that the 3:90.1 gear sets from Randy will do me well, as I plan on a Gear Vendors behind the T-400! Having 2 trucks complicates things, and now I see why the original rear unit was replaced with the 14-bolt unit; cost, availability, and: COST! That 14-bolt suits me fine, but those welds on the shock mounts still bugg me! Rear Disc set-ups seems to be a familiar changeover for these, even with the rather LARGE rear drums existing on it! Guess my time now is better suited to dictate what I really have, make choices based upon availability of what I have and then proceed forward. Looking at restoring my Longhorn has complicated my approach to doing so, and this rear axle situation is becoming problematic, at best for the current moment.......... Decisions, Decisions.......... ![]()
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS ![]() |
#31 |
For what you'll pay for a set of 3.90 gears,..I could ship you a 4.10 third member with a detroit locker in it...probably 2 at the cost of those new gears.
I want $300 plus shipping for 4.10 with detroit locker if interested PM me. |
#32 |
I might have missed this but,make sure the axle this guy has is from 2wd or 4wd.The difference is in the spring perches.Reworking them/reworking the shock mounts,six of one/1/2 dozen of the other.
#33 | |
Someone on here once reasoned that the D60 was stronger than the Eaton because it was under 2wds with the BB. I disagree...its just because of the 3.54 gears. The Eaton was used under all the 1 tons, and just by examining the 2 you can see which is stronger (Eaton). Just the gear problem.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
#34 |
here is what is under my C/30:
#35 |
So I assume that the HO is all a 10-bolt securing pattern....?????
#36 | |
#37 |
Having issues
My 52 came from a 71 camper special. It was leaf sprung. 4.57 gears, factory detroit. Sold my open 14B with 4.56 gears, minus shock mounts, and brake lines, for $200. Bought my 52 for $200 the same day.
Quando Omni Flunkus Moritati. The Man's Prayer: "I'm a man, but I can change, if I have to, I guess." |
#38 |
Just an FYI last I knew Randys Ring and Pinion no longer makes any new gear sets for the HO72. When I called the best they could do for me was a used 4.10 set and they weren't even sure it was out in the shop. Call around and you may end up having your decision made for you. I ended up pulling a center chunk from a local yard for $100. I got 4.10's and will be putting a 5.14 axle that I have in a parts truck under it soon because the 4.10's just don't cut it for me. I found out I had 5.14's in it originally after I had installed the 4.10's and it makes a huge difference. I am now having to downshift to second on some hills around here with a load where as before I could keep it in third. In second now the thing is screaming and I am climbing at 20 mph and the folks stuck behind me are not happy.
86 Silverado C10 back to 305 power! 67 C30 Dually Dump, with 350 transplant, Rockhauler 05 Duramax 3500 "If at first you don't succeed, try a bigger hammer" Member of the 1-Ton club! |
#39 | |
Having issues
#40 | |
4 eyed fever
1971 GMC 2500 4x4 1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto. 4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!! |
#41 |
Cantankerous Geezer
On the 3.90 gears, Randy had quit making them several years ago, since Art Houser was making them. Art died in Feb., his widow closed the business. I thought that since Randy has added the gears to his website, that he was making them. He had them priced over $500 before, iirc.
On the HO52/72, the main difference is the brakes and drums. The carrier and gears(pumpkin) interchange. AFIK the 10 bolt was dropped with the 73 model. The shock mount brackets are easy to replace. Find a pair that suits you, then get out the angle grinder and cut the welds on the existing ones. Find someone with a stick welder, drain the lube and put on the new ones.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
#42 |
Im pretty good on GM stuff, but this is getting sort of confusing to me what was standard issue on these trucks!
#43 | |
I don't know this for sure myself, though. We need the search function back...
#44 |
I said it earlier in this thread, I'll say it again..you could get either rear diff in a 3/4 4x4 dana or eaton.
#45 | |
