Old 10-26-2005, 10:19 AM   #26
redhead69
fugedaboutit
redhead69's Avatar
Re: por-15.....
Originally Posted by 4x4Poet
Hmmm....
I have only brushed on POR15 and I always use a respirator if only so I don't have to smell the product. Never had a problem. If you weren't so experienced with using automotive paint products, I'd have suggested you check the respirator filters for saturation or deterioration. I'd have also suggested to check the mask for proper fit and sealing.
Can't say I know what happened, but you obviously experienced contact with the stagnant product's fumes.
whatever.. my point is that if it happened to me it could have effects on others too..
Currently truckless
redhead69 is offline   Reply With Quote
Old 10-26-2005, 10:38 AM   #27
Inthuwind
Straight jacket required
Inthuwind's Avatar
Re: por-15.....
I've heard about Rust Encapsulator thru Eastwood's~Is it better???
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 10-26-2005, 04:35 PM   #28
wolfthing2000
Re: por-15.....
De Javu with this whole thread. Its kibnda like the Twilight Zone ,or that movie Ground Hawg Day. But who am I to talk, I'm postin here too!!
Zero Rust!!!!!!!!!!!!!!!
wolfthing2000 is offline   Reply With Quote
Old 10-26-2005, 05:27 PM   #29
Inthuwind
Inthuwind's Avatar
Re: por-15.....
so what you're sayin' is...
Old 10-27-2005, 12:12 PM   #30
wolfthing2000
Re: por-15.....
Zero Rust!
Old 10-31-2005, 04:38 PM   #31
silvertonguedevil
silvertonguedevil's Avatar
Re: por-15.....
One more question....After I have my frame sand-blasted and de-greased, should I put an epoxy primer on the frame or just go straight to the POR-15?
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 10-31-2005, 05:06 PM   #32
Boydness
Projects follow me home...
Boydness's Avatar
Re: por-15.....
If you are degreasing with the Marine Clean, you can spray and then rinse off the Metal Ready for a base. You will need that for the POR-15 you plan to apply. You need a good surface, rust is actually the best, the zinc leftover from the Metal Ready gives it something to grab.
If you do not use the Marine Clean and Metal Ready the POR-15 may/will come off in sheets, where it did not bond to the metal due to oil or whatever.
'51 Willys Wagon (SBC 350)
'56 Willys Wagon (SBC 350)
'77 Chevy Corvette 350
'79 Chevy G30 (Coachmen) 350
'79 Chevy G30 (Transvan) 350
Boydness is offline   Reply With Quote
Old 10-31-2005, 06:21 PM   #33
71-longbed
Its Magically Delicious
71-longbed's Avatar
Re: por-15.....
eastwood rust encapsulator is a good product too .. Its thicker than por-15, so it shows alittle more brush strokes. eastwood RE is also UV resistant unlike por-15 ...
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 10-31-2005, 08:16 PM   #34
Inthuwind
Inthuwind's Avatar
Re: por-15.....
Apply to bare metal--no primer
Old 10-31-2005, 11:19 PM   #35
wolfthing2000
Re: por-15.....
"0 Rust"
