Old 11-16-2005, 11:49 PM   #26
byrd
Union Electrician
byrd's Avatar
Re: Need to fix my fuel gauge
I think you may have a grounding issue, is the dash all working besides the fuel and lights? if not groun, then the power feed to the cluster, I'm pretty sure tha tis the only other things it could be.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 11-17-2005, 02:57 PM   #27
5150
C10 Club Tennessee
5150's Avatar
I've checked the power to the cluster feed fuse and I have power there.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 11-17-2005, 05:17 PM   #28
5150
C10 Club Tennessee
5150's Avatar
I checked the plug that goes into the back of the fuel gauge. It has 11 different elements that plug in back there. I checked it for power and it has NO POWER. I checked all 11 and nothing. I've also got a hell of a lot of static in the truck when I get out I'm shocking the crap out of myself.
Where would the ground be on the cluster?
Bryan
www.gmtruckshow.com
Old 11-17-2005, 10:32 PM   #29
5150
C10 Club Tennessee
5150's Avatar
ttt
Bryan
www.gmtruckshow.com
Old 11-17-2005, 10:42 PM   #30
byrd
Union Electrician
byrd's Avatar
THe cluster gets its ground from the wiring harness. looking at the plug for the gauges in the truck, on the bottom( wires away from you) the third wire from the left should have 12 volts on it. Now you for sure have a grounding problem ie getting shocked from static. You need to check the grouding of the frame moteor and cab, I believe there are seven total. One is pass side frame rail to cab, motor block to cab(1 maybe 2 like that) and a few others I don't know all the locations off hand, but you should start there. Randy
Zip:40272
Old 11-18-2005, 10:02 PM   #31
pritch
pritch's Avatar
Originally Posted by yellow69
Well, if it helps I do not have any dash lights. They come on for a second and then go off SOMETIMES, but most of the time they are just off.
This sounds like what I went through.
See the bad spot in the circutboard? That killed the gas gauge and all the lites that were on that side of the break. BUT-after I found this problem, the gauge still didn't really work right, and I found that it had been stuck in the same spot for so long it was siezed up. I switched the gauge itself and it works fine now.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 11-21-2005, 04:55 PM   #32
5150
C10 Club Tennessee
5150's Avatar
Still battling this problem. I posted a pic of the plug on the back of the cluster. I have no power to this plug. The cab is grounded by a ground strap underneath the passenger side of the cab. I have power to the cluster feed fuse like I said before, but not at the end of this plug.
The printed circuit appears to be grounded twice on the back. Would I possibly just need to change out the printed circuit? I would of thought if this plug had no power then it can't be the printed circuit (YET?)
Bryan
www.gmtruckshow.com
Old 11-22-2005, 12:13 PM   #33
5150
C10 Club Tennessee
5150's Avatar
ttt
Bryan
www.gmtruckshow.com
Old 11-22-2005, 06:43 PM   #34
5150
C10 Club Tennessee
5150's Avatar
C'mon guys somebody's got to have experience with this. I know it's an annoying post, but I need to get my truck put back together before Thanksgiving.
Bryan
www.gmtruckshow.com
Old 11-22-2005, 07:46 PM   #35
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Yellow69, coming off the plug in your last picture, if you follow it down the wires, there are a couple of black wires. Some are for the battery indicator and one is the ground for the panel. It clips onto the back of the dash metal via a U-looking clip. Make sure this clip is grounded well, ie.bare metal on the dash. After that, turn the ignition to the on position and check the pink lead coming into the plug. You should read 12V there. It powers the rest of the dash panel. Are your temp, battery indicator lights working? You said lights not working, but I didn't know if this meant the dash illumination, or indicator lights like ALT, BRAKE and stuff like that. Are your turn signal lights coming on when you use your turn signals? Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 11-22-2005, 10:07 PM   #36
5150
C10 Club Tennessee
5150's Avatar
Here's a pic of my gauges. I don't use the alt/temp lights. When I have my turn signals on I can here them ticking.
Also I have no instrument panel lights at all.
I did find that black wire with the clip on it I thought I had it grounded well, but I'll check again. Where does it go originally?
Bryan
www.gmtruckshow.com
Old 11-22-2005, 10:14 PM   #37
red71cheyenne
Back in the sticks
Both of mine went to the edge of the dash metal on the right(while facing the dash)side of the dash. I mean on both of my trucks, not grounds by the way. Anyplace back there with a clean bare piece of metal should work. Did you say earlier that you had power coming to the fuel guage terminal on the fuse block? I can't remember now. If you have no lights on the dash for turn signals, it sounds like you have more issues than just the fuel guage. Do the temp and battery guages work?
2011 K1500 Suburban
2014 K1500 Pickup
Old 11-22-2005, 10:33 PM   #38
5150
C10 Club Tennessee
5150's Avatar
That is originally a 3 hole bezel. The gauges are all aftermarket. They all work, but sometimes the Tach does not read good. Yes I have no dash lights or fuel gauges. Even the battery light or the brake light don't work.
Bryan
www.gmtruckshow.com
Old 06-10-2007, 04:35 PM   #39
garold99
Bump of an old post, but I'm curious. Did you ever get this problem fixed and what actually ended up being the problem?
garold99 is offline   Reply With Quote
