#26 |
yeller
Re: Check out my buddy's truck.
GM NEVER made a 73-87 crew cab short box...2 or 4 wheel drive. If you see any of them, they were done by a conversion company or by the owners themselves.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 11-12-2005 at 09:31 AM. |
#27 | |
Until Seventy Times Seven
The stance looks good. Boy, those 17s look like 15s. BTW, although it is a 3/4 ton, did he use drop spindles designed for 1/2 tons? There's been questions in the past whether drop spindles for 3/4 tons exists or whether they are the same regardless of the rating. Again, thanks... ![]()
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
#28 | |
Insert Witty Text Here
Slonaker |
#29 | |
You're right, they are 5 bolts. But, Tx FF mentioned that it was 'technically' a 3/4 ton. My guess is that he's using dropped spindles, rotors, A-arms and crossmember from a 1/2 ton. ![]()
#30 | |
Maybe the OP will tell us. ![]() Slonaker |
#31 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Sorry for the confusion.
He used a complete 1/2 ton front crossmember and suspension with the BellTech stuff for 1/2 ton application. The reason I said it's "technically" a 3/4 ton is that the title if for the original 4 door heavy duty donor truck he started with. In Texas, that gets him off the hook on needing catylitic converters and smog pump and junk. Just pure hotrod SBC under the hood that passes inspection every year without worry.
#32 | |
#33 |
Man! that is one sweet ride.
90 454ss 92 454ss 00 Silverado 08 Avalanche LTZ |
#34 |
Happy to be here
![]() Join Date: Mar 2000
Got any more pics?
#35 |
Diesel Addict
Nice! I think a 2WD SB Crew Cab is going to be the next project for me.
1979 C-10 Silverado w/ Olds 5.7L Diesel |
#36 |
I liked it better as a 4x4, but still very nice.
#37 |
87 short crewcab
This is question for tx firefighter
i need to find out what your buddy did about the rear shocks,when he put the 1/2 ton rear end in it. im building one also,youve probably seen it , listed as 87 shortcrewcab. is there any way i could get in touch with him, i have a few questions. you can send me his number by e-mail or have him e-mail me. thanks-donnie tbirdman88@msn.com |
#38 |
Hah. That gives me ideas. I just picked up a 79 Crewcab yesterday from the engine builder in my town. It's a 3/4 ton, I think I'll leave it that way, with the 14 bolt and big lug wheels, They make some decent looking 8 luggers nowadays. But I'd like more info on the shortbed conversion if he has any. I'd like to shortbed my truck I think. But that truck is probably one of the sickest I've seen. Do they make drop spindles and trash for 3/4 tons?
Brandon |
#39 | |
Not sure about the lowering stuff, but as far as making it a shortbed: Get your new bed. Toss it up on there (after you remove the longbed of course ![]() Congrats you now have a shortbed. Its not as much work as it sounds. Park brake cables are $10/each new from LMC. I got a junkyard tank, brake line and bed for $450, $78 to have my DS shortened and balanced with new u-joints. $60 for a friend to come over with his welding rig and help me chop and weld it back. All in all about 2 days hard work. ![]()
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ Last edited by bluex; 03-16-2006 at 06:16 PM. |
#40 |
87 short crewcab
hillshotrods.com
check out this link, this is one they did ,it was in the may 2004 truckin magazine. donnie-87 short 1/2 ton crewcab |
#41 | |
its just $$$$$
#42 |
very cool truck! it looks much better on the ground!
Kyle 70 Model Short Fleet ![]() |
#43 |
Professional Grade
Is your buddy from here in Ardrossan?
There is a rig that is the perfect clone of that one up here, and yes, its absolutely gorgeous!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
#44 | |
AttentionDeficitDisorder
I am about to build another one this week, but this time im going to attempt taking a complete reg cab shortbed and just stretching the frame it 33" under the cab and just swapping the reg cab out for a 4 door cab. i initially thought this would be a quick and easy swap but upon closer look under the 2 cabs the crew cab has straight frame rails and the reg cab frame kicks up after front body mount. Shouldnt be too bad but that does ad a little twist to the plans. I will post info and pics of the build if anyone has any interest in seeing this done. btw, beautiful truck! Looks awesome!! Last edited by milehightoyz; 03-26-2006 at 12:29 AM. |
#45 | |
#46 |
the green machine
very nice! i think a little better as a 4x, but still nice. not a big fan of the cowl hoods on our year trucks though. just my .02
1975 Silverado - 450 horse crate 383 stroker, 20" Centerlines, Flowmaster exhaust, Hooker headers, full MSD ignition & more... 2003 Suzuki TL1000R 1985 Kawasaki JS550 hull - project ski - WILL have - 650, footholds, custom paint, 4* bars, bilge setup, and more... My pictures |
#47 |
MAN!!!!!
TX FIREFIGHTER, Your buddy's truck is sweet looking!!!!!! I love the color!!! Respectfully
Billy ![]() ![]() 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! ![]() ![]() ![]() I'M IN THE MARKET...AS IT WERE! |
