Old 11-18-2005, 10:20 AM   #26
71RestoRod
71RestoRod's Avatar
Re: overflow
Originally Posted by 72 longhorn BB
I like it!
So you used a coolant overflow cap on a washer fluid bottle, right?
What car did the coolant overflow cap come off of?
Yes. Again, I got mine from Wes at Classic Heartbeat, but the cap was used in lots of GM cars from ~'70 through the mid eighties. Search the web for that part number and you will several applications including Pontiacs, Corvettes, etc...
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 11-18-2005, 02:29 PM   #27
68Stepbed
68Stepbed's Avatar
Re: overflow
76Bonanza, yes I ran a line from the rad. cap to the bottom of the canister.
The canister actually has two tubes coming out of the bottom. One is flush on the inside, the other sticks up about 3/4 of the way. If the coolant gets over the second one it just dumps out. Mine has never filled that much if ever. It does work as a recovery system though. There would have to be a lot of fluid for it to puke out.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-18-2005, 04:25 PM   #28
76bonanza
76bonanza's Avatar
Re: overflow
nice 68 step I think I will run a hose to the outside of compatment for now does anyone know if 3/8 fuel hose will work?
Were did you get that from 68step? I saw CPP has some for about 35.00 dollars.
Also you said I ran a line from rad cap? Mine comes out the side of rad neck not from the cab. Is yours different?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 11-22-2005, 09:13 PM   #29
76bonanza
76bonanza's Avatar
Re: overflow
68 step were did you get it? and does it have a drain or do you just pull the hose to drain it?
1968 c10
lowered 3" 4"
Old 11-24-2005, 05:52 PM   #30
53burb
53burb's Avatar
Re: overflow
This is http://cgi.ebay.com/ebaymotors/monte...spagenameZWDVWwhat I used. The picture is backwards. It mounts on the passenger inner fenderwell right next to the battery. It fits perfectly. The hose connects like this one http://cgi.ebay.com/ebaymotors/OEM-1...spagenameZWDVW
53burb is offline   Reply With Quote
