Old 04-02-2006, 08:16 PM   #26
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 58 3100 Ifs
I found that out recently and have taken it off. I plan on getting some ceramic coated header and only wrap the tube near the steering u joints and over the trans tail shaft.
dwcsr is offline   Reply With Quote
Old 04-02-2006, 08:51 PM   #27
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 58 3100 Ifs
I am very impressed with your fabrication work you have done. It looks really good. What type headers are you going with? Block huggers? Shorties? Or are you fabricating your own?
CAL 58 GMC is offline   Reply With Quote
Old 04-02-2006, 10:49 PM   #28
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 58 3100 Ifs
Thanks for the compliment. I think I will go with Sanderson headers becuase they have a long header that has tight bends at the head or the dynomax cheapy ceramic. They are dynomax on there now. It depends on the wallet when that time comes.
Old 04-03-2006, 10:44 AM   #29
Jebb1978
Jebb1978's Avatar
Re: 58 3100 Ifs
Agreed there my friend. I admire your ambition, you are paving your own path. Your truck is going to really stand out because you are doing everything differant than everyone else.
1959 GMC project
Jebb1978 is offline   Reply With Quote
Old 04-04-2006, 01:43 AM   #30
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 58 3100 Ifs
Thanks, I wanted something that was different. Plus I had more time than money and thats what drove some of the ideas.
Old 04-06-2006, 11:50 PM   #31
Jebb1978
Jebb1978's Avatar
Re: 58 3100 Ifs
Keep up the good work, it's going to turn heads for sure!
1959 GMC project
Old 07-01-2006, 08:50 PM   #32
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 58 3100 Ifs
This was my rainy saturday project. modify the left header to get clearence on the steering shaft. I used pieces from another set of headers. The center 2 tubes were shortened at the bend out of the header flange and re piped below where the steering shaft crosses them. It allows for a better angle on the steering shaft and more clearence around it. I need to clean up the welds, sandblast and paint them.
Old 07-23-2006, 11:02 PM   #33
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 58 3100 Ifs
I needed inner fenders that fit the 75 IFS and leave room for the rubber brake line, I was going to make some but that proved harder that it looked. What I found after some trial and error was that the original inner fenders actually were just about right clearence wise except the high side of the upper A frame and the front rubber brake line. The inner fenders had this little hump for clearnce of the 58 brake line but it was on the back side of the Aframe and I needed it on the front side.
So what I did was cut out a 13" section on each inner fender and put them on opposite sides. This made the hump in the front where I needed it and tapered the sheet metal to clear the high side on the A frame. I wish all of it went that easy.
Below are the pictures of the right side in progress.
Old 07-24-2006, 11:37 AM   #34
Jebb1978
Jebb1978's Avatar
Re: 58 3100 Ifs
Neat idea! That won't even look custom!
1959 GMC project
Old 07-24-2006, 12:41 PM   #35
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 58 3100 Ifs
I know it it looks as if it were factory, some times you just luck out.
Old 07-24-2006, 05:02 PM   #36
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 58 3100 Ifs
Here it is all but the filler and primer. I think I'm going to roll the edge thats just over the brake line for saftey sake.
