#26 | |
its just $$$$$
Re: Reverse 4 link
Think about this for a minute...... people have been using 4 bar setups on the front of hot rods with straight axles for longer than most of us have been alive......this has the bars running forward and attached to the axle, no different that that rear setup, yet this is accepted as probably the best setup you can have for a straight axle....hmmmmm.... now, tell me why it wont work agian..... |
#27 |
Re: Reverse 4 link
Well the front axel is not driving the car; the rear wheels are. so if your pinion angle changes drastically while driving you are well.... SOL. The front wheels dont do anything but spin; there is no power to them. Also if you have 2 bars in front and 2 bars in the rear you limit your travel and if you do try to get much lift you just start to twist the axel in a forward or backwards motion depending on the upward or downward travel of the bags.
Keith |
#28 |
Re: Reverse 4 link
For every person with a spark of genius, There are a hundred with ignition trouble. ![]() |
#29 | |
its just $$$$$
Re: Reverse 4 link
I agree 2 to the front and 2 the the rear is possible the worst setup. |
#30 | |
Hollister Road Co.
Re: Reverse 4 link
#31 | |
Re: Reverse 4 link
I haven't seen any like this, but a reversed 4-link could be designed to provide anti-squat. Simply move the rear mounting points of the upper bars slightly upwards compared to a 4-bar setup. This would place the instant center in front of the axle where it should be. This would also change the pinion angle similarly to how a normal 4-link would. There may be some dynamic issues that I'm not considering here, but I don't see it as the inherently horrible design everyone seems to think it is.
Mike Lackey '68 C10 |
#32 |
its just $$$$$
Re: Reverse 4 link
#33 |
its just $$$$$
Re: Reverse 4 link
not a very good picture but you can see the bars. I will find a better one.
#34 |
![]() Join Date: Apr 2004
Re: Reverse 4 link
nice car. I would drive it.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
#35 |
Re: Reverse 4 link
Well since Air Ride Technologies has made quite a bussiness in the suspension department, I will believe what they say and that a "Reverse 4 Link" is a BAD BAD IDEA!
Until one of you who think it is a GOOD idea has a company and makes them and becomes one of the largest manufactures of suspensions, well maybe then I might think about it! ![]()
#36 | |
Re: Reverse 4 link
BTW that's a bad A$$ car
Please become a site supporting vendor to advertise a business in your signature. you can do so here Last edited by valleycustom; 11-30-2005 at 01:14 AM. |
#37 |
Re: Reverse 4 link
Also with a front end with a 4 link you have the nose dive effect when you slam on the brakes....causing the front to plant and the rear to lift. NOw if you have a reverse 4 link on the rear and you slam on your brakes the rear end will want to be pulled out from the rear....make sense?
#38 | |
Re: Reverse 4 link
Also just because ART is a large company doesn't mean they are always right. Keep in mind that it's likely a marketing team that wrote that response up there, not an engineer. Their job isn't informing the public on rear suspension design, their job is to lead people to buy ART products. For instance, note this line: "With a normal 4 link, when you hit the brakes, the rear suspension geometry wants to lift the rear of the vehicle... therefore trying to plant the rear tires and assisting the braking action." This is flat-out wrong. The reason the rear lifts is due to weight transfer, not because of the suspension geometry. The 4-link will have some amount of anti-squat designed into it which, while accelerating, creates additional loading on the tires for more traction and pushes upward on the rear of the chassis. This will have the exact opposite effect during braking since the braking torque is in the opposite direction as the accelerating torque. So, there will be a downward force on the chassis and reduced loading on the rear tires. In cars that have a lot of anti-squat, the effect can be great enough that tire tires will lift off the ground causing brake hop.
#39 |
Re: Reverse 4 link
Something else you need to think about is 95% of using doing or talking about these mods have bags. Dependning on set up you are looking at anywhere from 5-24 inches of lift. Ya you are going to cause some problems. On those old ford buckets if one decided to install a reverse 4 link they are most likely using coil overs. Nice ride; Yes! A lot travel? No! So that is something to consider, also fast bags is right about the pulling direction, but a lot of these old school buckets are mearly show cars/trucks. So backing out of the trailor or even driving a few blocks to the show usually will not cause any problems.
Keith |
#40 | |
its just $$$$$
Re: Reverse 4 link
#41 |
Re: Reverse 4 link
Hey bagged74,
Sorry for the miscommunitcation; I was speaking about the rear when I was talking about coil overs. I posted that right after I woke up this morning and was not all there. I agree with you it does work it is just not ideal. Keith |
#42 |
Hollister Road Co.
Re: Reverse 4 link
I came across this link on 4 links and what happens in each of the install types we were discussing
http://www.illconformity.com/videos/linkvideo.wmv |
#43 |
Re: Reverse 4 link
That's a decent video, it illustrates how the suspension moves pretty well. And in the reverse 4-bar you can see that the only difference in movement compared to the regular, 4-bar is that the driveshaft could get pulled out of the tranny as previously mentioned
But... The suspension travel he is showing is rather extreme, which is better for illustration purposes, but doesn't translate to reality. The links on my rear suspension are 30" long IIRC. If they were able to move 45 degrees up and down, that would give me a total travel of ~42". The reality is that I get a total of about 8-10" of travel with my airbag setup. That translates to up to ~9 degrees of angle up and down, and the differential would move fore-aft less than 0.5". Nothing to get too worried about, even in a reverse set up.
#44 |
Hollister Road Co.
Re: Reverse 4 link
It is a very exaggerated travel. When I saw it my thought was that with a plywood cut out of the axles housing and some 2x4’s you could do a actual size mock up to get an idea of what would fit and what the clearances look like and estimate the C notch.
