#26 |
Re: Air Ride For Dummies
I installed the C-Notch on both sides. The only clearance issue I had was the track arm hitting the frame on the right side. I simply moved the track arm bracket underneath the lowering block instead of on top of it and presto!
67 SWB |
#27 |
With the C-notch installed I made a template to locate the holes needed to mount the bags.
67 SWB |
#28 |
Now I am trying to figure out where I want to mount the compresor and valves.
67 SWB |
#29 |
Getting an idea of how it will look aired out.
67 SWB |
#30 |
The LuvShack Garage
Sweeeeeeeeeeeeeeeet, keep us posted
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#31 |
nice looking work. She will be back on the road in no time.
Brandon project 67 swb bagged on 20" Coddingtons |
#32 |
Looks Good! That is a tall bumpstop in your notch, is that the one that came with it? The reason I ask is that my notch came with a much shorter one. It might could get you another inch closer to the dirt.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#33 |
Hey..... did I see you driving to Home Depot on Saturday? I noticed a white 67~68 that had ralleys & was lowered. I was behind it driving up HWY66 & then it pulled into HD so I didn't get a better look.
#34 | |
67 SWB |
#35 | |
67 SWB |
#36 |
![]() Join Date: Apr 2005
Wink Tim,
Send me your address. I have a couple of spare ones. Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#37 | |
67 SWB |
#38 |
Never Done?
![]() Join Date: May 2000
Where have you guys bought c-notches that came with short bumpstops? I'm going to be buying a notch sometime in the next few weeks (if all goes as planned), and was going to buy from CPP, but not if I can get one with proper bumpstops someplace else. Sorry to hijack the thread, just want to ask while it's on topic!
#39 | |
![]() Join Date: Aug 2005
#40 |
I got my c-notch kit from CCP and it came with short bumpstops. My ART rear airbag kit also came with a set of short bumpstops.
Rob TW - bumpstops will be headed your way tomorrow.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 01-10-2006 at 11:29 PM. |
#41 |
Thanks Hart_Rob, I owe you one.
67 SWB |
#42 |
Happy to be here
![]() Join Date: Mar 2000
Oooooh Noooo Mr. Bill
#43 |
How is the load carrying capacity of airbag systems such as the one you're installing on your truck (looks awesome by the way!)? Is it merely a factor of the airbags? Compressor/airtank size? No difference?
Keep the build going, it is looking great.
Have mercy, I'm recovering from my 4x4 addiction. ![]() |
#44 |
Your welcome. Keep pics coming.
Rob
#45 |
I stold N2Billet's idea for compressor placement. Hope he doesn't mind.
67 SWB |
#46 |
I assume that SMC valves can be mounted in any position, does anyone know otherwise before I drill a bunch of holes?
67 SWB |
#47 | |
Happy to be here
If I were you I would consider mounting it at the rear. Here's mine.... |
#48 |
The LuvShack Garage
This is looking great, question for you guys, since I hope to do my 2wd
blazer this year, where do you reccomend putting the air tank or tanks?
#49 |
Should be an easy switch if it drives me crazy. Thanks for the heads up!
67 SWB |
#50 | |
67 SWB |
