01-15-2006, 05:25 PM | #26 |
'71 chevy s.bed/s.side
Re: What did you get done this weekend?
Worked about 4 hours at the Cat house Sat. morning, more blocking the doors & fenders. Sunday after church took the wife & daughter to Carrabas for dinner. Went to the garage and looked at the truck, got cold and went back to the house...and here I am. Will start back on it Monday night.
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
01-15-2006, 05:32 PM | #27 |
Went skiing
01-15-2006, 06:11 PM | #28 |
Wet sanded my 69 Corvette getting it ready to buff. I need to get the Vette done so I can start on my 72 truck.
01-15-2006, 06:28 PM | #29 |
Took the old ratty box off the 72 and started prepping the frame for paint and washed my daily driver Dodge Charger yesterday. Today I shoveled snow, and started diagnosing the check engine light on the work truck. We got freezing rain at about 6:30 this morning, followed by about 6-8" of snow. The streets have not been cleaned since the last 6-8" of snow we got, so the town is at basically a standstill. I'm now in the market for a pre-76 4 wheel drive, this is rediculous...
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
01-15-2006, 07:53 PM | #30 |
I'm watching you!
I only got to think about my truck
Mike
2012 Chevrolet Silverado 1500 Z71 4WD 1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP) 1992 Chevrolet S10 - LS swap project 1968 Chevrolet C-10 longbed fleetside - sold |
01-15-2006, 08:33 PM | #31 |
I'm fighting a power steering conversion. Some time in my trucks past the steering box was WELDED on. Looks like 3 of the 4 bolts were broken at some point so they decided to weld the box on. I'm guessing it was pretty easy to weld around the box but it's not real fun to cut it off.
01-15-2006, 08:53 PM | #32 |
Needs a Big Block
Started a new project ive been putting off for too long!
http://67-72chevytrucks.com/vboard/s...61#post1555961
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
01-15-2006, 08:55 PM | #33 |
River life......
I put a spacer lift and add a leaf on my DD (tacoma).
In my Jimmy I put my tranny and transfer case in. Started sandblasting my grille and ran out of sand about halfway through. I did get the garage cleaned up some though. Wife was kind of happy about that. |
01-15-2006, 09:34 PM | #34 |
I changed the tranny fluid and filter in my '00 Z71.... what a mother explicative explicative! I probably did it wrong, but I had to remove the heat shield on the PS, the front driveshaft, the shift cable and bracket, after all that, I then had to either remove the exhuast, or unbolt the trans mount and jack it up, I did the latter, THEN the stupid rubber seal for the filter is actually metal and that was an explicative to get out, but I got it done in a whopping 3 hours. No wonder chevrolet charges 130 bucks to do it..... Sorry, fellers I had to rant!
As far as the 67, I've been looking up parts, checking prices, comparing, checkin ebay..... lets just say in the next couple of months... I'M GOING SHOPPING
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
01-15-2006, 10:35 PM | #35 |
resU deretsigeR
Saturday was my big day to finish my c-notch and paint. Got the notch cut and some more parts cleaned and painted. Organized a little in the garage and pondered while the paint dried. Today I just puttered about like Rain Man and painted my front crossmember and trailing arms. HOPEFULLY tomorrow I'll get all x-members and suspension installed and have a rolling chassis again so I can sweep out the garage....yeah...grade 8...grade 8 on the frame...11 lbs of grade 8 on the frame...yeah... gotta put grade 8 on the frame...yeah
Brent |
01-15-2006, 11:20 PM | #36 |
Nothings as cool as my 72
On Saturday I went to church and spent they rest of hanging out with my friends. Sunday, I worked for about six hours at my part time job making money so I can use it towards the truck and now I'm doing my homework. Can't do anything with the truck until it warms up again in the spring time, since I work on the truck outside and I can't paint in this cold weather.
1972 C10 Longbox In the middle of body off restoration Rebuilt 355, turbo 400, 3.42 12-bolt Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding. |
01-16-2006, 01:25 AM | #37 |
Installed used choke stat I bought off the board a while back.
Pulled the Rochester 2GV off the intake manifold, went to swap the rebuilt one I picked up off the board a couple months ago, found that it won't fit (wrong manifold). Will be reposting that for sale very soon. I tore the original 2GV apart to find out what was wrong with it. For one the float was sunk (small crack filled it with gasoline), and it looks like the accelerator pump plunger was probably too worn to work properly. Crossing fingers that when I fix the float and rebuild it that the power piston still works right and it just might be okay. I compression checked the engine, so far not good. #1,2,3,5,7 have ~ 110psi, #4 is ~70psi and #6,8 have ~130psi. Bought an old-timey oil can so I can squirt some oil down in #4 to see if it is the rings or not. 6 of the 50-mile old plugs were oil fouled, one was so bad it had chunks baked inbetween the electrode and ground.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... Last edited by 69TowRig; 01-16-2006 at 01:25 AM. |
01-16-2006, 02:02 AM | #38 |
sounds like everybody got alot done i wish i would made progress on my progect instesd spent the weekend with the wife and kid maybe tomarrow i can get something done
01-16-2006, 02:31 AM | #39 |
I didn't get alot done today , but i did manage to remove my 68 hood , the only one around to help me was my red-headed wife , so that was fun , she's getting pretty good at helping . I envy you guys with boys at home to help Getting ready to plasti - blast the hood and cowl , have a lttle work to do straightening the hood , i may look at buying a cowl hood , haven't decided yet . Headers are off getting ceramic coated , p/s and alt brackets getting powder coated , next weekend i'm changing intake / carb etc . Still have alot to do before spring .
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
01-16-2006, 02:16 PM | #40 |
I installed the ashtray cupholder conversion kit I recently bought from Early Classic. It's a pretty cool modification.
01-16-2006, 07:49 PM | #41 |
Oil trash and damn proud of it
me and my buddy installed my new manifold, valve covers, and carburetor. All Edelbrock. In addition, I installed my new front brakes (bout dang time) then we ran into trouble, left it for Sunday and went and had... err... "fun" with some cruisin, and some... uhh... beverages. anyways, the next day we tried the carb, don't fit still, put the stock old Quadrajet on it, and found we had oil leaking out of the back. yay, so this week we're trying at it again, haha. that's my story of the weekend, lots of fun gettin down and dirty! really dirty, I dunno how, but I ended up looking like a grease depository (if such a thing exists)
Mark 1997 K1500 Z71, 14 bolt SF 3.73 posi, Bright Blue Metallic. 6" Superlift 1972 C-10, toolbox, p/s, 350/TH350/3.73 open, black int., bronze 2008 Dodge MegaCab. H&S tuned 6.7 Cummins. Fast Four Tons Some of my pics http://s107.photobucket.com/albums/m294/69-350/ |
01-16-2006, 10:28 PM | #42 |
someday it will be done!
drove back to the farm friday night.Got up early sat.morning,hooked onto trailer and headed south to buy a 72 bed and ls door.Got home off loaded and pulled the blazer into the shop and replaced the leaky intake gaskets and failing thermostat.Sunday,changed oil cuz I managed to dump alittle antifreeze into the engine the day before,checked and regaped plugs and checked the timing.Drove back to Lloyd last night and relaxed for a few hours with a few glasses of spiced rum.Looooooooong day today .
Oh and the entire time I dreamt about actually doing something on the 72.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
01-16-2006, 10:36 PM | #43 |
i found a front clip without the hood on saturday .
on sunday i got a drivers door grill bumper dash cluster glove box door gas cap and dome light out a 68gmc flatdeck thatwas going to the scrap yard |
01-16-2006, 11:24 PM | #44 |
I finally got the old 1947 Lincoln SAE300 arc welder running. The original Hercules flathead straight 6 had some stuck valves that I freed up with penetrating oil and tapping 'em with a small ball pein hammer. Got it running yesterday and I rolled out the welding leads and ran a couple beads with it and this machine runs a better bead than the new Miller 250's we have at our school. Had to change the oil in it, the new filter cartridge is in tomorrow. I can't wait!!!! Now I need to build my BBQ pit, fix up a new trailer for it, and build a headache rack for my Grandpaw's truck.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
01-16-2006, 11:37 PM | #45 |
Never Done?
I bolted on my engine towers and tranny x-member in an attempt to actually get this thing mocked up so I can make some real progress this year. Look at all that nice shiney hardware! *edit* oh yeah, I hacked out two rivets on the front x-member so I can mount my sway bar. First time grinding/pounding out rivets, boy does it ever pay off to have the right tools for the job!
01-17-2006, 01:11 AM | #46 |
Love to see the details of that blast cabinate myself.
01-17-2006, 05:19 PM | #47 |
Aluminum slot wheels rule...
Yesterday I hooked up a professional exhaust. Made it from old 2 in'' tailpipes running right off the rusty headpipes . Exits right under the t-case. Now I need some gas to start her up.
01-17-2006, 05:53 PM | #48 |
I thought I'd accomplished something in 12 hours - man you guys must work and not drink! HA! Actually, I closed in this roof that was hanging off the end of my garage - it'll give me an additional 8x20 area for MORE storage - I need it as the 4 car bays aren't enough. geesch! I just might end up with room for my truck - after the mower, chipper, spare central air unit, extra frig, weedeaters, blowers, etc, etc. are out of there.....
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
