04-16-2007, 11:04 PM | #26 |
Re: Electric fans?
Here's mine. Couple Merc Sable fans with custom shroud and Spal controller. haven't had a chance to "real world" test them, but I've let the truck get up just north of 200 and kicked them on and they got it down to 160 pretty quick. They are also pretty quiet.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread Last edited by SactoJim; 10-04-2007 at 05:22 PM. |
04-16-2007, 11:11 PM | #27 | |
Questionable
Re: Electric fans?
Wes has not had this problem. Mudder67 (I believe) is the only member I know who has had an overheat problem (until he manually drilled out his shroud). After that, all was fine.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
04-16-2007, 11:17 PM | #28 |
Re: Electric fans?
Third, fourth and fifth on the kits from wes. to me performance and looks go hand and hand and the kit from wes is a 10 in both. Plus he is a nice guy.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
04-16-2007, 11:26 PM | #29 |
laying low
Re: Electric fans?
I have seen some other shrouds that have about 6 holes in them with a rubber flap covering them just for this reason. Flaps stay sucked closed under low speed driving but open up at highway speed. May have been a flexalite setup or one of the others so there may be something to this. Maybe only when using the smaller diameter fans.
I know someone here is sure to have a pic of this setup.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
04-17-2007, 12:15 AM | #30 |
Re: Electric fans?
Thank you gentlemen I think you just solved my heating problem on my 67 I have been dealing with for the past three years. Around town or low speeds temp is fine but on highway it heats up, not dangerously but heats enough to concern me. I have a dual fan setup off of something we had in the shop a while back and those suckers move some serious air. But the possibility that they cannot freewheel fast enough is very real. I will drill the shroud out this week as I will be taking my truck on a three hour trip on friday and let you all know how it works out. I hope it fixes it since I have replaced water pumps, thermostats, new radiator(twice),tranny cooler with larger fins, and whatever else I could do and nothing made any difference what so ever.
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80 Nice ride 67 Chevy C-10 LWB Built 350 TH-400 Wifes ride and family rig: 2001 Furd Expedition 5.4 Liter Kickin back in Rolla,Mo. USA "Do the thing you fear most and the death of fear is certain" Mark Twain |
04-17-2007, 12:16 AM | #31 | |
Questionable
Re: Electric fans?
04-17-2007, 12:33 AM | #32 |
The Original HotRod KnifeMaker
Re: Electric fans?
Another happy camper with the set-up from Wes
Dave 69 GMC SWB 2WD 454 Turbo 400 |
04-17-2007, 01:45 AM | #33 |
Re: Electric fans?
I will post up some pics tomorrow what I did with mine. I am in no way knocking Wes's shrouds but only having one 16" hole in it I felt like there wasn't enough flow. I was runnning temps up to 205 and close to 210 on the highway. It really hasn't been hot here to really test it but it seems to have cured the problem by drilling a series of 2 1/2 in. holes in the shoud. The shrouds Wes sell are first class and I would buy another.
04-17-2007, 10:03 AM | #34 |
Questionable
Re: Electric fans?
The fitment of Wes's shrouds are incredible, and the powdercoat job is superb. It is incredibly streamline and low profile. The fans are heavy duty, and not anything you can buy at the store. I hope nobody thinks I'm bashing on his product, here.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 04-17-2007 at 10:03 AM. |
04-17-2007, 10:44 AM | #35 |
Re: Electric fans?
I used O'Reilly stocked 16" and 14" fans. Wired them with their own relays. It was probably overkill on my part (I am running a 402 with AC). I ended up wiring a manual toggle switch to the dash because I couldn't get the thing up to operating temp without leaving them off for the first 15-20 minutes.
Caleb |
04-17-2007, 12:56 PM | #36 |
Re: Electric fans?
As promised thanks to my youngest. (I'm not even dressed yet). Here are some pics I promised. The 3" shroud that goes around the fan was made by myself and a friend. We had done it before I cut the holes thinking it would help the fan draw better.
04-17-2007, 02:24 PM | #37 |
Questionable
Re: Electric fans?
Hey Mudder, what'd you use to cut the holes so nice and neat?
04-17-2007, 02:42 PM | #38 |
Re: Electric fans?
You can get the round saw blades in different sizes. They have a drill bit in the center. Work great..
04-17-2007, 03:02 PM | #39 |
Questionable
Re: Electric fans?
Ah, I have one, thought they were only for wood.
I have some greenlee knockout punches as well that I think might work...will hafta look into it.
04-18-2007, 03:01 AM | #40 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Electric fans?
I run Two 14" PermaCool fan's in a homemade steel shroud.No holes in mine.NO cooling issues.
Those 14" PermaCool fans draw 2800CFM.Got em from Summit.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
04-18-2007, 09:52 AM | #41 |
Chief Honcho In Charge
Re: Electric fans?
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
04-18-2007, 12:08 PM | #42 |
Questionable
Re: Electric fans?
Here is the link to the full installation (with pictures) of the unit that ClassicHeartbeat (Wes) sells:
http://67-72chevytrucks.com/vboard/s...d.php?t=216128 With that said, a point was brought up inside that install thread: the 123classics unit doesn't look like it mounts very securely to the radiator IMO. I like the look of the setup, but I wonder about its effectiveness. I really do like that it comes pre-bundled with relays and wiring and stuff, though.
04-18-2007, 10:09 PM | #43 |
laying low
Re: Electric fans?
Shifty, I sure like the looks of your install. Real clean. After considering the stock fan shroud has like an 18 or 20" opening in it I don't see why an electric dual 12" fan setup won't cool just fine as is. 2 12" openings equal 24". Should be plenty of air blowing through there running down the road.
Something else I thought about is I have read where some power feedback happens with fan motors turning after the key is turned off allowing the engine to run on a bit. Anything to this?
04-18-2007, 10:29 PM | #44 |
Questionable
Re: Electric fans?
It's not a matter of cooling better. It's a matter of more horsepower because you're not forcing your drivetrain to push a big machanical fan Personally, I didn't have a place to put a fan.
Power feedback isn't really possible if you are properly using relays - the second that power is removed from the relay, the circuit is broken, and power cannot be sent through to the fans.
04-18-2007, 11:50 PM | #45 |
Re: Electric fans?
Shifty, I am gonna drill mine out tomorrow(thursday)night and I won't be back on until probably sunday evening, but I will be sure to post how it worked out when I get a chance. I am confident it will cure my problem. My truck on a 100 degree day will climb up around 220 on the interstate with my foot kickin it down the left lane. I retarded my timing on the roadside and it seemed to help a little but I want it to stay between 180-195 most of the time like it used to.
04-19-2007, 05:56 PM | #46 |
Re: Electric fans?
Mine is from Wes also.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
04-19-2007, 06:26 PM | #47 |
Farm Truck
Re: Electric fans?
You could eat off that engine. Very Nice
1969 CST/10 1984 K5 Blazer 4x4 2016 Dodge Ram 2500 4x4 Mike Jersey Village, Tx |
04-19-2007, 06:53 PM | #48 |
F.A.S.T. president
Re: Electric fans?
You guys are starting to make me worry. I don’t have any holes drilled in mine.
I cant decide to take it back off now and drill some holes before the rest of the front cap is on
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" |
04-20-2007, 03:37 AM | #49 |
Re: Electric fans?
jamis.......... try it the way it is. with the two fans you may not even have any problems. i just had the one 16" hole in my shroud.
04-20-2007, 07:56 AM | #50 |
Recovering Truck Driver
Re: Electric fans?
I used the fan and radiator setup out of a 91 chevy lumina minivan. The fan fit in the stock location on the radiator, and the radiator fit in the stock mounts on the truck. I don't have it on a temp switch yet, which has bit me in the butt a couple of times when I walked away from it and left the fan running.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
